Water leaks....
Where the brake master cylinder and vacuum brake booster are at, it’s connected to the pedal assembly. There’s a gasket that goes between the body and pedal assembly. It’s also possible that critters built up a nest and is preventing the water from throughly draining away and is backing up. You also need to have that plastic cover and associated hood gaskets in place.
