Water pump
I need to replace the water pump in my 2002 XJ8. I ordered the new part, but my problem is I don't know how to remove the old one. I downloaded the JTIS manual and I could not find anything about the water pump removal.
I used the search feature and could not find anything specific.
Has anyone done one of these replacement installs thanks!
![](https://www.jaguarforums.com/forum/images/kirsch/misc/progress.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/buttons/edit.gif)
Drain the radiator. Remove the supercharger drive belt if XJR. Loosen the three screws, which secure the water pump pulley.
CAUTION: When releasing the belt tension, never apply any torque in a clockwise direction to the pulley center bolt (left hand thread) as it could subsequently loosen. Remove the drive belt from the generator and accessory drive. Use a wrench on the center bolt of the belt tensioner idler pulley, to turn the adjuster assembly to the left against spring tension. While holding the tensioner against spring tension, remove the drive belt from the generator pulley. Release the tensioner slowly and remove the wrench. Disconnect the belt from the other pulleys, as necessary, to move it clear of the pump pulley.
Remove the pulley from the water pump. Remove the pulley securing screws. Remove the pulley from the water pump.
Remove the five bolts, which secure the water pump. Remove the water pump from the engine. Remove the gasket. Remove and discard the water pump gasket. Remove and discard the water pump O-ring seal. Clean all the mating surfaces.
Installation
Just reverse the removal procedure. Tighten the pump securing bolts to 11-13 Nm and the pulley bolts to 10-14 Nm .
Installation
bigcat777 (02-10-2014)
Installation
Installation
I just want to ask you a question regarding a 98 VDP water pump and thermostat housing. For the water pump, I ordered a new one from the dealership and for some reason, it doesn't match my existing one. The location of bolts is somewhat different. Any suggestions? Also, would you recommend swapping the plastic thermostat housing with an aluminum housing (sold at Welsh Enterprises, Inc.). Thanks. Bill
Bill, My observations on this forum would indicate the aluminum thermostat housing is the way to go. The rear bolt/s (can't remember 1 or 2) under the intake can be tricky to get out without removing the intake manifold, but possible. Try some searches for this and you will see some posts regarding removal of these bolt/s, and "special tool" creations.
Good Luck![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Ralph
Good Luck
Ralph
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
Ralph
Good Luck
Ralph
By all means replace the plastic housing as it will leak sooner than later. If you have the aluminum housing in hand do not be bashful about destroying the old one. Break it apart with a pair of pliers. That will allow easy access to the rear bolts. Cut a slot into the head of the bolts with a Dremel tool to allow screwing them down with a screwdriver before tightening them with a 'crows foot' wrench, short socket, or bent wrench. If you cannot relate to the aforementioned do a search on the terms.
Another thought; the bright aluminum housing looks a little out of place on an otherwise black engine. Jaguar painted the plastic housing black, no reason not to paint the aluminum housing black also.
You should be able to open/download things by now. Here is the link to the most popular discussion on BlueTooth / Ipod. I still have my T605 in the box. Maybe when it gets colder and I am looking for some heated garage projects along with my reach motor issue.
https://www.jaguarforums.com/forum/s...4&postcount=13
Ozzy_UK
45
02-19-2019 02:05 PM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
