Water pump o-ring?
Water pump o-ring?
Just got a new Jag water pump for the 2000 XJ8.
It comes with a thin metal gasket.
It looks different from other, thicker gaskets on the internet with built in rubber seals.
The manual mentions renewing a pump o-ring.
Is this necessary for this version of the pump?
Thanks again,
Dan
Thanks again,
Dan
The following 2 users liked this post by Sean B:
Alvin Burns (02-01-2011),
Dan R (02-01-2011)
Thanks. There is an ring indentation on the new metal gasket which I suppose takes the place of the old o-ring. I will use Permatex water pump gasket sealant for peace of mind.
Sorry about bringing an old thread back from the dead I figured it would be better if I just added my question on to this one, rather than start a new thread. When you (Sean B) say that a smear of sealant would be fine, what area are you referring to? Around the central portion, or around the central portion and the openings on each side? I ask, because the new water pump that I bought has a metal gasket, and no o-ring. I plan to go pick up some of the Permatex sealant tomorrow, so I can get my car put back together. But I want to make sure that I don't over-apply it, or put it somewhere where it shouldn't go. Thank you
Ozzy_UK
45
02-19-2019 03:05 PM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 12:56 PM
