Waterless Antifreeze - Has anyone used it?
Received 2,263 Likes
I was sceptical, but investigate it, considered the advantages/disadvantages on different areas, and tried it, and am glad I did for many reasons as mentioned.
There is another XKR with twin-screw running as well for a couple of years on Evans, no cooling issues/bursting pipes there as well.
I agree there isn’t much attention needed to the stock system/setup as long as your coolant pipes are in good condition (low miles).
What strikes me is how you negate the effects of pressurize/depressurize movements, and worse what pressure does if you develop a leak.
I am not claiming that at all, not sure who does, but oh boy, I rather have a pressure less system when a pipe goes than one is under 15 psi any day.
Parts are arriving daily now so I'll be installing this weekend, maybe, depends. Seems I got the AIRTEX AW4124 pump with the black plastic impeller. Rockauto shows the beige impeller but this is what they sent me. Also the Thermostat housing seems to have problems with the casting. Thermostat drops in too far on the right side so no rubber left to seal. I'm sending everything back and starting over. I wonder if I should just go with a metal impeller pump!
Any ideas?
Any ideas?
Have read to many posts about the bad quality of the metal ones, and the standard OAT coolant Jaguar use doesn't have any cavitation inhibitors so you would need to swap coolant as well. If you use Evans, then its no problem it seems, as it doesn't cause the cavitation issues. The stock plastic water pump is good, no need for metal.
