Weird TRAC / ABS Fix
I've been troubleshooting an ASC/TRAC unavailable issue for the past week or so. After testing all the circuits from the harness at the module I'd pretty much pinpointed the issue as a module failure. Was planning repairing the module this weekend. Here's the fix - we had some nasty storms moving in on us last night so I moved the car to a safer spot. I get in it this morning and I realize I'm staring at a clean spedometer - NO Warning Messages NO Amber light. Before I got no response from the TRAC OFF button on the console (no light). This morning it lights up and all looks good. Just wondering, part of my circuit check was a physical inspection of each sensor and leads. While I was there, I also cleaned each sensor head. After that I checked resistance at the module connector and all checked out, but I still got the warning message and amber light. Just trying to figure out why they warning disappeared days afterward. The module is sealed so I wouldn't think humidity is bridging any bad solder points on the board.
I get ASC/TRAC messages all the time in damp weather or after a rain storm. When things dry up for a day or so, the messages go away. Sounds like the same deal as bluerdog. I figure there has to be some connection that has a leakage short when it gets damp, but I haven't figured out where yet. So far, it's just an annoyance. I do have to be sure that I take my car in for its state inspection on a dry day! They don't like error codes...
Cheers,
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
