Weird transmission problem?
Hi guys . My transmission was working fine for while now started problem again I want to try everything before replacing it . Now when I turn on the car then shift to drive it shifts fine then after about 10 minute stuck in 3rd gear and then it show gear box fault on the dashboard then if I turn off the car and start it again it will run fine for another 10 minute and then stuck in 3rd gear again .
Could it be stuck solenoid? Bad speed sensor?
Thanks .
Thanks .
Received 13,204 Likes
Hi mobile1,
You need to have the car scanned by a system capable of reading the Powertrain (P-prefix), Chassis (C-) and Network (U-) diagnostic trouble codes. Your car is going into Limp Home Mode, which locks the transmission in 3rd gear. There are many possible causes, and the fastest way to narrow down the diagnosis is by having the DTCs scanned.
Cheers,
Don
Cheers,
Don
The following 2 users liked this post by Don B:
AD2014 (01-16-2021),
MountainMan (01-16-2021)
Hi mobile1,
Cheers,
Don
Cheers,
Don
MountainMan (01-28-2021)
Can your scan tool read Chassis (C-prefix), Network (U-prefix) and Body (B-prefix) codes? Most OBDII scanners can only read the Powertrain (P-prefix) codes.
Any signs of transmission fluid leaks at the oil pan gasket that could suggest your fluid is low?
Have you checked the electrical connector at the transmission for oil contamination?
The following 3 users liked this post by motorcarman:
Unfortunately my foxwell can't read that .
No leaks and fluid is clean and fine level .
Will check connectors and the abs sensors too
Is your speedometer misbehaving? That would be a clear sign of one of the rear ABS wheel speed sensors being contaminated or faulty. Off the top of my head, I think it's the right rear sensor that provides the vehicle speed signal but double check the documentation.
It's the rear right ABS sensor indeed -- I had this exact issue very recently (speedo at 0, + ABS/ASC dashboard error messages).
However, in my case it didn't trigger a limp home mode, just intermittent and very quick (aaaand very scary) shifting issues.
The sensor was not dead though, just covered in grease and dirt: cleaned it and that was it.
Either way, worth checking that out before trying anything more complicated (and costly, i'm guessing)
Don B (01-18-2021)
Igloo112
10-18-2008 10:37 AM
