What is this? 2000 XJ8
motorcarman (12-03-2023)
Just a heads up I don't think the xj8 had a kickdown switch. I think it's more or less just a pedal stop for the accelerator and keep in mind where you place that pedal stop will affect your wide open throttle reading on the pedal position sensor. I know because I just had to adjust mine when I hooked up my scan tool I noticed that wide open throttle was only 84% so I had to remove that pedal adjust the pedal stop so that I could achieve 94% wide open throttle.
pcolapacker
05-23-2021 11:52 AM
