That is the overflow tank from your coolant reservoir.
If you follow the inboard-upper black hose from the coolant reservoir, it runs along the inside of the front fender and enters the top of the overflow tank just under the ABS unit.
Thanks! I hadn't spotted it's connected at the top I was under there trying to get the cooling fan relay/module out and it didn't look to me like it was connected to anything. I stand corrected. (or rather, I lay on my back in the dirt half under the car corrected)
