what is beeping?
no - not like the parking system, though I had not thought of that. Short beep, not the high pitched beep of the parking assist, but closer to when you press a button on the A/C., however louder than that. The interval does not appear to be standard, just random, but no sooner than a minute or so apart, sometimes 10 minutes. Single beep only.
Does the A/C have some kind of feedback that beeps at you if you do not have auto selected?
Press a climate button and see if it is the same beep. Look at the recirc button. See if it is beeping when recirc turns on or off. IE, if recirc is on, look at panel when beeps and see if recirc is now off. Then wait for next beep and see if back on. Also check the audio and see if TA is showing.
LOL....another tidbit of info that would have been handy.
Turn off the phone. They beep when on because a: no signal, b: they do not seem to charge well any more. You can disconnect the connector behind rear vents and get the harness from nicestuffonline.com that plugs right in and change it to bluetooth.
