What Could Cause This "Steering Issue?"
Hello Gentlemen:
I never noticed this before I had new front shocks and new tie-rods ends installed, but I've recently noticed that when I drive over the smallest of road imperfections, the steering wheel moves slightly left or right.
I know for a fact that I need lower control arm bushings and this is yet to be done.
In addition, I'm also going to install:
4 Front upper control arm bushings
2 Subframe bushings
2 Lower + 2 Upper ball joints
2 Sway bar bushings
Can someone please tell me what this odd sensation might be caused by?
Thanks so much!
SirJag
2 Subframe bushings
2 Sway bar bushings
Thanks so much!
SirJag
If it is minor, it is "bump steer". The relationship of the parts controlling the steering geometry changes on compression or rebound. Particularly the relationship to the tie rod ends. (hard to explain without writing a screed).
Most cars do it, unless it is a race car that has been "bump steered. FWD/AWD cars are also subject to "torque steer".
It is predictable which way and how much a particular car will bump steer, but not usually known to most street drivers.
Still, an experienced driver in their usual car will instinctively nudge the steering wheel one way or the other when say, hitting a dip on a sweeping onramp at speed, to compensate for the bump steer effect. They just "know" from experience.
SirJag (06-24-2011)
I wonder if the new shocks have anything to do with it... or something my mechanic did in the process of installing the shocks or tie-rod ends. OR, those lower control arm bushings, along with the new shocks and tie-rod ends, are causing that feeling to be amplified?
Can you tell I'm speculating?
SirJag
rusty37
04-05-2020 08:40 PM
