what are cylinder liners made of 4.2 litre
dc4prez (10-01-2014)
Quote from the S491 service bulletin describing the Nikasil issues:
Following an extensive development program, Jaguar has decided to introduce cast iron cylinder liners in lieu of plated bores for all AJV8 engines.
The liners I checked from an early 4.2 block looked cast iron, but I am no metallurgic, so I honestly can't tell for sure.
Engines with supercharger
The 4.2L engine with supercharger consists of:
an eight cylinder 90 degree 'Enclosed V' configuration liquid cooled aluminium cylinder block
with dry cast liners
pistons of open-ended skirt design, with two compression rings and a compact two piece oil
control ring
two aluminium cylinder heads, each incorporating two hollow camshafts manufactured in
chilled cast iron
four valves per cylinder
aluminium tappets and top mounted shims
valve covers manufactured from Thermoplastic
fuel injectors each with twelve holes
engine front cover manufactured from aluminium which accommodates the crankshaft front
oil seal
multi row primary and single row secondary chains drive the camshafts of each cylinder bank
an aluminium bed plate
oil spray jets in each cylinder bore
a cast iron crankshaft
fracture-split connecting rods in sintered-forged steel
brackets bolted to the front of the cylinder block which are used to mount all accessories
a single, multi-vee belt which drives the front end accessories
stainless steel exhaust manifolds
an advanced engine management system incorporating electronic
control ring
chilled cast iron
oil seal
I've never seen liners that were part of a casting - I know there are replacement liners available - Avos sent me a P.M. regarding this - in which he mentioned - "I used a piece of broken off sleeve" - I hope this helps.
We used to run a weld vertically top to bottom for all dry liners to shrink them prior to removal
"Aston Martin hand-assembles a special version of the AJ-V8 for the 2005 V8 Vantage. This unit displaced 4.3 L (4280 cc/261 in³).
"In May 2008, Aston Martin released a new design that used pressed cylinder liners instead of cast-in liners. This allowed for thinner liners, and a higher capacity of 4.7L for the V8 Vantage"
Panthro (06-06-2017)
Replacement cast iron liners from one manufacturer have outer diamater of 89.79mm and inner 85.73mm which can be bored out up to 1mm. Using stock piston the wall would be ~3.8mm and with 86.5mm ~3.3mm. I guess this works for a bit bigger bore liners also. Ductile iron is another story then.
Well.... ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
If you don't care any money spent, you just make it to 5.1 litre, TS, 10:1 compression pistons for E85, BIG injectors, ported heads, high lift cams, big MAF and TB, replace orginal ECU by fully adjusted one, big fuel pumps + maybe BAP, bigger E85 resistant fuel lines and you finally have 800++bhp. If that's not enough you simply add 100-150hp NOS kit.....hahaa....and you are quite fast then ...
PS. Since you are from Germany you know the exact crank located there.
The plan was to go with new crank, pistons, rods, sleeved cylinders.
Heads will be reworked by a guy who builts the early group B rallye engines for Peugeot, this includes vales, seats, guids, rework inlet/outlet etc.
What i should do with the cams, atm i dont know...
TS from Andre is a must!
Complete rework of the inlet section is mandatory ( atm i try to get access to a flow bench at my university )
Exhaust, is the smallest problem, but it will be equipped with a active vale system.
The issue with E85 is very interesting!So its super cheap and has some advantages over regular petrol.
On the other side its very aggressiv to the surrounding materials, like Al
So i need to think of it.
Bivalent operation mode would be a perfect compromise.
The biggest problem in my eyes will be the ECU , you need to completley program a configuration for this kind of setup and spend several hours on dynos, and that s very expensive!
Anditional to this, you have to look on the other corresponding electronic systems of the car. And what should be done with the communication between the ECU and the transmission?
And at the end of the Day it should be driveable and looks like a normal car.
Brakes/lim slip diff are obligatory
Best regards
Best regards
