What did you do to your X308 Today?
Old 04-25-2017, 11:59 PM
CharlzO's Avatar
Replaced my passenger side wheel bearing. The sound of silence has never been so welcome. And it even managed to take out a good chunk of the rattle out of the front end. Leads me to believe that it had been going out well before it actually started humming on me.
Tomorrow will be emptying all the tools out of the trunk, for the first time in months. I no longer need them for anything on the car! The only things I have left now to sort, are going to be new end links (again - I really need to stop being cheap), and fix my driver's door actuator.
  #1982
Old 04-26-2017, 01:44 AM
Fabworkz's Avatar
Complete set of coils after I cooked one which also blew the ignition fuse
  #1983
Old 04-26-2017, 05:14 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
4 pin or 2 pin?
  #1984
Old 04-26-2017, 09:14 PM
AudioBob's Avatar
Took imy XJR to a cruise-in tonight and was the only Jag there. Parked amongst several Mustangs and the muscle car crowd liked it, but didn't know what an XJR was as they thought it was just a Luxo-barge. I'm a Mustang fanatic as I have one as well and I had fun with the other car guys.
  #1985
Old 04-26-2017, 10:53 PM
Steve W's Avatar
I got my X308's tires rotated and balanced. Taking it on a road trip to AZ in July.
  #1986
Old 04-27-2017, 03:23 AM
Stu 1986's Avatar
Yesterday I cleaned a few things, sorted something out that's been bothering me for a while and went on a nice afternoon drive with my dog.
I'm going to give her a wash shortly as she's a little bit dusty from some of the country areas I drove around.
  #1987
Old 04-27-2017, 03:49 AM
jimbov8's Avatar
You washing the car or the dog.
ericjansen (04-27-2017)
  #1988
Old 04-27-2017, 12:11 PM
KidRock'n's Avatar
Made the nearly 1700km drive home from uni. for the summer. VDP made it despite the engine death rattle and a bad RR wheel U-joint. Hoping to get that sorted out next week (the U-joint at least).
Pulled the pretty kitty out of storage and set to work vacuuming and detailing the interior. She's getting new rubber tomorrow and other goodies next week. Stay tuned.
Daim (04-27-2017)
  #1989
Old 04-27-2017, 12:14 PM
KidRock'n's Avatar
Today I've also been working on my 20 spoke VDP summer wheels, painting between the spokes with a little can of silver Tremclad and brush. It's tedious work, but you can see the obvious difference
The following 4 users liked this post by KidRock'n:
Daim (04-27-2017), ericjansen (04-27-2017), King Charles (04-28-2017), Patioboater (04-28-2017)
  #1990
Old 04-28-2017, 11:44 AM
Finn's Avatar
Originally Posted by Finn
Put summer tyres on today.
Four wheel alignment. Front had toe-out but now with toe-in XJR drives very, very well.
But each Hankook appear to be out of round and the car shakes at highway speeds. Tyres were re-balanced but that does not help if the tyres are not round.
Off to the tyre shop tomorrow - ka-ching.
  #1991
Old 04-28-2017, 02:54 PM
King Charles's Avatar
Received 1,021 Likes on 741 Posts
Originally Posted by Jennifer S Flavell
Wheel badges installed. They are identical to the OEM ones but a different color background. I think the black looks much sharper then the gray.
I wasn't 100% sold that the green was the correct hue, so I found some used ones for 25$ shipped !
1988-2012 Jaguar Wheel Badge Set Center Cap Green Silver Wheel Badge Set Premium Upgrade number of 4: Galaxy Jaguar Used Auto Parts & Wrecking Junk Yard
That site has a plethora of Jag ware w/ good price points.
  #1992
Old 04-28-2017, 08:05 PM
Patioboater's Avatar
That is inspirational!
  #1993
Old 04-29-2017, 04:42 AM
Einhead's Avatar
Since the summer is finally abbout to hit Sweden it was time to wash my car.. again.. and tidy it up on the inside.. I also removed the rear mudflaps and cleaned up behind them... since they are actually fitted quite poorly they are moving about in the wind and with dirt collecting behind them and the paintwork tend to wear down slowly..
I also took the time to replace the totally unreadeble display on the factory installed telephone.. the MOTOROLA 8700. Luckily the phone belongs to an era when it actually was possible to take them apart and replace bits and pieces inside them. The only thing you actually can not replace is the main cirquitboard since it is specially designed to be able to talk to the Jaguars interfacebox located underneith the armrest between the front seats. The display is mounted on a separate daughterboard witch also contains the contactpoints for the keypad, and after i VERY carefully picked the phone apart it was really easy to swap it out.
The parts you might need you can pick from a phone of the correct model. I collected a few so i in the future can replace either the display again or the plastic cover where the flipflop cover is mounted. The plastic tends to crack at the hinges.
Well.. new tyres got fitted as well.. :-)
/E
  #1994
Old 04-29-2017, 06:56 AM
Fast71SS's Avatar
Today I get the pleasure of moving all the part-out inventory to inside my house (master bedroom as it seems). I got a letter from the home owners association. "Outdoor furniture only, NOTHING else" with the threat of a $50 fine.
  #1995
Old 04-29-2017, 10:29 AM
nilanium's Avatar
My transmission fluid was a very opaque brown, and now it is not. Drained the TC as well since that had a plug, think I may have overtorqued that accidentally but as long as it doesn't leak... 8 bottles of fluid was just barely not enough to replace lost fluid, one more should do it, but even with the fluid a bit low it seems to be better already. Something I didn't expect was that reverse got much quieter.
Traced my strange trunk behavior to a bad inline diode, but then it turned out that was the wrong diode. The trunk light diode may still be bad, I haven't tested it yet, but now I need to figure out what that one goes to, just digging around in the electrical guide a bit. Or maybe just replace both and see what happens.
Originally Posted by BobRoy
Hows the interior???? Just kidding. Nice to hear it's back on the road again.
Much better than the exterior/mechanical! Aside from a worn drivers seat and the usual cupholder and headliner sort of things, it's in pretty good condition for a car of its age, maybe 7.5-8 out of 10. Enough not to worry about it for a long time. The biggest problem with it is that it's not black
  #1996
Old 04-29-2017, 11:34 AM
Finn's Avatar
Oil change with Shell Helix Ultra 0W40 and Mann W 719/7 filter.
  #1997
Old 04-30-2017, 04:23 AM
Stu 1986's Avatar
LOL, I ended up washing both as it turned out.
The drive I went on was around the rural area I grew up, I went exploring some of the back roads I used to go driving round when I was younger. I took this photo of a little tunnel I used to go through a lot, it's very low and narrow. It makes me smile because I used to think it was a secret entrance when I was a small child.
jimbov8 (04-30-2017)
  #1998
Old 04-30-2017, 04:40 AM
ericjansen's Avatar
Received 1,352 Likes on 927 Posts
And ... did the Jag fit through?
  #1999
Old 04-30-2017, 09:01 AM
KidRock'n's Avatar
/E
Still rocking the good 'ole Motorola eh? My man
Yesterday afternoon I took the 100 into downtown Toronto for lunch with the ex - was quite the lovely time! Still needs a RF wheel bearing, secondary fuel pump, fuel tank sender, alignment, parking sensors sorted, etc.. but Gosh I love how that thing drives haha
  #2000
Old 04-30-2017, 09:06 AM
KidRock'n's Avatar
This is EXACTLY how I imagined the English countryside as a kid when I was sitting in front of the TV with a box of Goldfish crackers watching Postman Pat (and his black & white cat).
Quick Reply: What did you do to your X308 Today?
