What did you do to your X308 Today?
#221
I replaced the red oil cap with the black "recommend castrol" cap and took off one of the cam covers to verify what upper tensioners I had - yep the plastic ones.
Which is odd because the tensioners, timing assy and water pump were all replaced 18 months ago and I have documentation for it. Anyway, I ordered up the aluminum ones today and will be taking care of that next weekend.
#222
#223
I had our engine oil, oil filter and air filter changed today.
First time using Shell Rotella 5w-40 T6 full synthetic motor oil. Bought 2 one gallon Jugs (needed 7 liters = 7.4 quarts).
I used Mobil 1 synthetic 0w-30 on the last engine oil change.
I read here on the forum that Rotella T6 cleans and lubricates the VVT mechanism.
Well I will see if it makes the engine quieter at startup.
Jim Lombardi
Jim Lombardi
#224
#226
#227
youngowner (05-20-2020)
#229
I drove it 60 miles to get Pizza. No heater on the way up, but it worked on the way
back. No check engine lights. A successful mission. Life is good.
Tip turning on ALL the electrically heated seats will take the chill off when the heater
isn't working. I did look at the replacement Heater valve sitting in the box. It will
get changed when it is not raining.
#230
Ok it was yesterday but got her majesty to come back to life after 2 weeks in coma. Cylinder wash was the symptom. A lot of great help from fellow jag lovers on this forum and she puuuuured back to life. Have a bunch of codes show up now, but in comparison to my fear of timing chain issue or dead engine - I don't care as much anymore ;-)
#231
#234
#235
Going to hopefully check the water level in the battery. I may also wipe down the Asteroid wheels. They are chrome and get noticeable dusty after driving 3 times. I need to also try to soak the key insertion place on the xjr keyhole on the trunk lid. I want it to work, and it is currently corroded.
#236
#238
Full detailing session yesterday as follows:
Full wash down
Soap up and second wash down
Car dryed and inner sills cleaned
T-Cut 2 light scratches.
Engine bay cleaned and back to blacked
Meguiars paint cleaner and swurl remover applied and Removed
Autoglym super resin polish applied and removed
Meguiars Gold Class Carnauba applied and removed
Mirco fibre buff up
Meguiars Endurance High Gloss Car Tyre Gel applied
Pictures will follow....
Full wash down
Mirco fibre buff up
#240
I did a rear break job on my "98" XJR. Pretty simple and straight forward really. It really needed it and I was waiting for good weather to arrive and that day finally came. The main advise I would give to someone deciding to do that is to make sure before you compress the caliper pistons is make sure to open the bleeder valve first, You DO NOT want to force fluid back through the line because it could damage the ABS pump with is a $1500 expense. It's not a hard job just a little time consuming so give yourself plenty of time. Have a great day.
