What did you do to your X308 Today?
#2421
Transmission shop called , the car's ready ! The A-drum had given away & it was totally rebuilt w/ the forged upgrade & pressure regulator valve. Total cost $2,200, now I know for sure all these cars' major "hot spots"(tensioners,A-drum,t-stat housing,etc.) have been addressed in mine, so I have that piece of mind going forward !
#2422
#2424
I hope the best for you and your car... Mine likes to 'play' with me. One day it will work Luke a gem. The next day a new clunk. 2 days later the clunk is a bang. 3 days later it has gone again. Next day you look under the car. All is fine. The next day rubber hanging off the wishbones where there used to be a bush The list goes on and on...
King Charles (11-01-2017)
#2425
Really glad it's back as I have been relegated to driving my Nissan Sentra. It's ironic the tranny waits to fail until I get rid of my previous toy/daily driver lol. Also happened after I addressed the majority of my "to-do" list (paint,ABS module,shocks,t-stat housing,pipes,knock sensor etc.) Only thing left on my list is front tie rods,ball joints & change the rear differential.
#2426
That's good news King Charles, now everything is sorted hopefully you can get some enjoyment from the car. I had the transmission valve replaced with the updated one as soon as the car's renovation was finished. There is a notable difference from how it was before, a good difference as far as I'm concerned.
When you drive one of these cars with everything in good working order, they really are a special thing. Mine is 15 years old now and there aren't any squeaks, rattles or noises she just glides along the road in a very dignified and gracious fashion.
#2429
Not mine but close, the brother just picked up a 1998 XJ308 3.2l (badged SE which is interesting as they are supposed to be a 2002 only model?) felt it was a bit down on performance, he has a X300 3.2 so has a direct comparison. Just happen to have a Seagate scan tool so dropped that on and hello 69% at full depression. Something not correct here. Check for slackness and no all tight under the bonnet, however the pedal has about 3/4 to 1” of free play.
The cable has a cable tie around the fixing of the outer sheath, cut it off and remove the square retainer. This allows the outer cable to move about 1/2” tighten that up relocate and recheck woohoo 100% full throttle. Much better
#2432
Car's back & she's purring, every shift is buttery smooth !
Here's the guilty culprit/usual suspect lol. Tech. said I saved them ample grief & myself money by shutting the car down instantly keeping the whole body from being riddled w/ debris.
She's now due for a thorough wash & leisurely cruise !
Sean B (11-03-2017)
#2433
#2434
https://www.mechanicadvisor.com/nc/n...e-transmission
Jim Hardy is his name, honorable guy whom knows his craft.
#2437
Ok day 2 on new transmission state, I'm noticing a "warble" on downshifts, it's like a wobble mixed w/a small bump. I'm thinking it's just the new friction plates & drum meshing . Only thing I changed was taking it out of "sport mode" which the shop apparently put it in to test. Maybe sport mode's meant for me. But I will have it looked at, if it doesn't clear in 200 miles. It's warrantied work, so no worries but I am super alert right now, so I sense everything lol. The blessing & the curse.
#2438
#2439
#2440
The one I found on E-Bay will take until next week to ship to me. My question is can I use one from the rarely used rear doors on the front drivers ?! I've searched the forum & there's some saying yes it will work, & some saying no ?!
