What did you do to your X308 Today?
Old 02-09-2018, 09:53 PM
King Charles's Avatar
Received 1,021 Likes on 741 Posts
Not even 750 miles since my transmission re-build, I'm getting a harsh 1st shift going into drive when it's cold. Never had that before the work, I think I am going to contact the shop & ask them to install the Trans Go Kit.
Only thing I've done different is keep it in "Sports" mode this time around.
  #2602
Old 02-10-2018, 01:46 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
So they only replaced the broken a drum? Is that what you told them to do? The amount of times I have explained what kill these trannies and that still happens...
The A drum isn't weak. The A drum can withstand a lot of abuse. It can't withstand pressure peaks from a worn main pressure valve.
If you're unlucky, your A drum is cracked again.
A.J.P (02-10-2018)
  #2603
Old 02-10-2018, 02:16 AM
A.J.P's Avatar
Did my pressure valve a couple of weeks ago myself and I notice the trans shifts smoother now(I thought it was shifting ok before but obviously it was not quite right)so it's done something,hopefully for the better.
If it wasn't for the good people on this forum I would never of heard about the pressure valve problem and the Trans Go Pressure Valve Kit,£50.00 shipped over from U.S.A. and fitted it myself,needless to say I'm very pleased.
Enjoy your cars,
Thanks,
Andy
Lower Valve Body Removed
Old Pressure Valve
New Pressure Valve
  #2604
Old 02-10-2018, 02:22 AM
They rebuilt the whole body & new drum. Apparently with the same flawed pressure valve. Work's under warranty, no worries there. If the car sits for a day or 2 the first shift into drive is harsh. I'm calling them Monday morning.
  #2605
Old 02-10-2018, 07:58 AM
Daim's Avatar
Is that a qualified or better said skills workshop with knowledge regarding the 5hp24? A friend just recently had his 5hp24 replaced by Jaguar. I told him to replace the valve body at the same time OR get a trans go valve fitted.
Local Jaguar workshop fitted a brand new or refurbished transmission WITHOUT the valve body and used his valve body incl. old valve. It didn't even last 2000 km. The A drum fractured and he is fighting with his solicitor to get the workshop to get it repaired under warranty.
  #2606
Old 02-12-2018, 02:38 AM
Stu 1986's Avatar
I had the valve replaced in my gearbox straight away when I bought my current XJ, having had my last one die because of the blown box I was dubious about trusting another 5HP24 box. However all seems well except for the irritating issue of the fluid level not being quite right and there being no easy or straight forward way to fill it. I was disappointed to see the dipstick thread didn't yield a positive result. I was thinking of looking into seeing if it was possible to fit some sort of adaptor to the transmission cooling line to enable it to be filled it from there. I read that's what some owners did on other brands of car.
  #2607
Old 02-12-2018, 05:34 AM
Daim's Avatar
In theory, manufacturing one ot the filler pipes with a dip stick shouldn't be that hard.
ZF says, the tranny is correctly filled, when the fluid level is in line with the bottom of the fill hole. So if a dip stick was fitted, the tube should sit a little lower so you can get a reading somehow...
  #2608
Old 02-13-2018, 05:08 AM
Update
Took the car out of sport mode & kept it in the heated garage the last 2 days, resulting in zero hard shifts. Now my "hard shift" is not the hunting for gears w/ higher RPM or the stall & bang into gear type. Mine was just a small jerk going from reverse into drive on my initial backing out the drive-way.
I spoke w/ the shop that did the trans. work I was assured the valve & valve body were both rebuilt & replaced along w/ the drum. Then I got the usual "cold temp.s change the trans. fluids viscosity on start ups etc." I assured them that the car's never done that before & it's storage conditions haven't changed. They said that old fluid was so bad/shot that it's consistency never changed despite temp.s lol ?! I was then told maybe there was a electrical flaw w/ the setting in sport mode as I never ran the car in that mode until after the work. Not sure about that either, so I am going to put it back in the shop. Have them do another thorough look over as it's under warranty etc.
  #2609
Old 02-14-2018, 03:13 AM
Update #2
Took car to shop @ 9 am, got a call to pick it up @ 5 pm. Oil's @ proper level w/ no leaks,the shift points in "sport" mode were off, they reset the computer & it tested to specs. I usually deal with the master technician/owner there, but I missed him today.
This is my third X308 & this is the 1st time I've ever had "cold transmission fluid" issues. So not quite sure I'm buying that premise.
If it resurfaces the car will be back in the shop as there is plenty of mileage & time left on the warranty. Even if they have to drop the valve body & double check the valve. I parked the car back outdoors w/ temp. in the low 40's FH. I will see what the next start brings.
  #2610
Old 02-14-2018, 10:38 AM
Daim's Avatar
After giving the car the wellies, I got a 'little' smoke on a cold start...
I will have to keep an eye out for this...
  #2611
Old 02-14-2018, 10:56 AM
Lady Penelope's Avatar
Received 1,386 Likes on 1,090 Posts
Daim , white smoke currently an issue with with this same engine :
Yours might be cold soak related .
https://www.jaguarforums.com/forum/x...-video-196623/
  #2612
Old 02-14-2018, 11:15 AM
nilanium's Avatar
Junkyard had an x308 XJR come in a few days ago (happens maybe once a year, so need to make the best of it) so I got a bunch of goodies off of that. LH taillight, completely intact full load breather, cruise control vacuum line, heater control valve, aux heater pump, and about a half dozen good XJR lugnuts - those things are worth their weight in gold.
If anyone is relatively nearby and needs it, the car has a full set of 5 B+ condition Pentas on it as of yesterday at LKQ Jessup.
The junkyard car also had some authentic Ray-Bans in the glasses holder, so I've got some nice driving glasses now
  #2613
Old 02-14-2018, 11:35 AM
harvest14's Avatar
How did the driver seat look?
  #2614
Old 02-14-2018, 11:49 AM
Daim's Avatar
What do you mean with cold soak? I only get that amount if smoke if I really hammer it and park it up hot. In the video the engine is not at full temperature (satt for about 30 mins).
I'll keep an eye on it
  #2615
Old 02-14-2018, 12:43 PM
Stu 1986's Avatar
Did it have heated rear seats? I'm trying to find a wiring harness for that aspect and the only place it seems I'll find one is the USA.
Ray Bans are the best, I've got a pair for every car
  #2616
Old 02-14-2018, 12:44 PM
By cold soak it's the very cold items that lose there springy nature and shrink and lose their seal like o- rings .
  #2617
Old 02-14-2018, 12:53 PM
nilanium's Avatar
Don't think so, it didn't have the rear seat heaters control panel so it probably doesn't have the harness (same as in my car, the XJR's only got heated rear as standard in 00). I'm assuming you need the harness going between the button panel and the seats themselves? I can keep an eye out for one if I see it, that's a cheap and easy part to extract, I'll try to grab it in the future if I'm there for parts off another car.
  #2618
Old 02-14-2018, 02:36 PM
Stu 1986's Avatar
The harness part number is LNF3526BA and it plugs into sockets already fitted onto the cabin wiring loom. In theory all I need to activate the feature is the harness, the two relays, the switch panel and the heating elements for the seats. I could use any elements as I've got the appropriate connector plugs in my spares. It's relatively easy to get to because all the needs undoing is the seat base which would expose the wiring loom.
The bitch is I actually had the loom once, I bought it from a seller in the USA for my previous XJ. I'd fitted a Daimler Super V8 interior but the seller had neglected to include the loom. I sold the interior and gave the loom away with it, and now I'm kicking myself over it. I'd promised myself I wouldn't try to fit heated seats in the rear of this car, but my need to tinker has got the better of me.
If you or anyone else in the USA spots what I need then please get in touch. I've tried searching US ebay, but I'm unsure what the term you guys use for cars being broken for spare parts.
Thanks,
S.
  #2619
Old 02-15-2018, 02:01 AM
Update #2
Update #3
Car's been parked outdoors w/ an average low temp @ around 55° FH, no rough shifts. Maybe there is merit to the cold temp affecting the fluid explanation. I really trust this company's work, they are a small family owned operation but 9 out of 10 people I asked about working on a ZF transmission, all pointed to this shop.
  #2620
Old 02-17-2018, 02:48 PM
Stu 1986's Avatar
Yesterday I gave the car a nice wash to get the winter grime off, then followed it up with a coat of aqua wax. I also took the time to clean the tail pipe finishers to get them back to being shiny and chrome (to ensure I reach Valhalla! ). She looked so good I decided to take her to work today, I love driving that car.
She'll be making a trip back to Coventry next week, I'm looking forward to that.
Quick Reply: What did you do to your X308 Today?
