What did you do to your X308 Today?
#2661
Replaced boot lid button 1998 XJ8 LWB. fixing the button was easy. But what a job to remove the housing.The boot housing is plastic. I was a amazed to find that the screws were moulded plastic with metal nuts. These promptly sheared off. I stuck the housing back on with epoxy resin, it seems to be holding. Very surprised that jaguar would use such a cheap component on their car.
#2662
#2663
Went to take a 400klm round trip yesterday but felt something wasn’t quite correct, certainly different from a warped disc!
Odd that it happened on Sunday but wife and I were in seperate cars and she forgot to mention that something didn’t feel right
Changed them out today cleaned up the old ones for now and replaced the pads while I was in there.
![What did you do to your X308 Today?-5a09bb39-4e2b-4b1a-8c8d-7ddf11e8cee4.jpeg](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/211075d1520329947t-what-did-you-do-your-x308-today-5a09bb39-4e2b-4b1a-8c8d-7ddf11e8cee4.jpeg)
I also changed out all the coils for new ones from China (because I could)
Old ones will be in the boot for a while just in case.
#2664
#2666
#2667
#2668
Not wanting to get into a war of words but what grill have you of the same model in both steel and plastic that you have weighed?
#2669
Finally replaced my front/shared muffler with the one I got from the junkyard, no flex joints on the junkyard one but it seems like it will get by without them. Reused the old cat flange gaskets and they leak with the exhaust, big surprise, but at least that's hopefully an easy replacement part to pick up from the local auto parts store. Finally fixed the damn rattle I had though, with the old muffler it sounded like the engine was about to explode itself all over the road, while now it just sounds like an old muscle car with the cat flange leak. I can live with that for now
the improvement is already massively noticeable.
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
#2670
Had more electrical gremlins recently due to the boot loom getting mangled up and shorting out. Having patched it up a couple of times i decided to start fresh and replace it with a good loom salvaged from another car. As there is no plug between the boot loom and main car loom there was only one option *snip*
Bunch of spade connectors were used to attach the new loom. I also opted to keep the excess cable length in case i need to repair the loom in the future. Having the ability to cut a damaged section out and shorten it will make the job much easier.
#2671
I compared the X300 steel pressed grill to te standard plastic x308 chrome plated one. For some reason the steel one, which is magnetic and on my car, weighs less.
#2672
#2673
Had a late night Jag fueled E-Bay spree :
Belt Tensioner #NCA7739AE
2 Sets Timken rear wheel bearing JLM1708
Door Switchpack Bulb DBC6244 x3
Wire Mesh Grill Inserts
Also made an offer on a clean SDZ half wood VDP wheel, we shall see if they bite !
Hopefully this coming weekend will prove productive !
#2675
Haven't done it yet but I have ordered and already received some more parts:
1x new water pump
3x 1l of Prestone universal coolant concentration (been using this for the last 3 years with no problems)
4x inner door handles with bezels in brand new condition for basocally nothing
4x exterior door handle (want to try something)
Had some fun this morning for the first time ever: key in ignition, turn to start: nothing. Again, key to start: nothing. Thought my battery was dead but every system started correctly. All noises sounded correct. Starter didn't click or so. About 10x turning the key and it started. So I assume it was the immobilizer. Do they go funny on the X308 sometimes?
1x new water pump
#2676
Daim (03-07-2018)
#2677
Do that every time I start any car... Wait for the fuel pump to prime and then turn. Didn't want to this morning.
#2678
This weekend's game plan :
Replace serpentine tensioner
J-Gate & Sport mode switch bulbs courtesy of our very own A.J.P !
Replace the black bezel J-Gate trim that was broken trying to install the ill fitting previously acquired J-Gate bulbs.
Climate Control display bulbs.
