What did you do to your X308 Today?
#2723
Replaced the water pump today... Just to find the tensioner bolt snapped on me. The bolt you use to loosen/slacken the belt... SNAP off. So a new tensioner has been ordered. Can't really test the pump.
The old one though was a plastic impeller model BUT it was fine. So it must have been changed along the lines OR it managed to survive. It had the steel gasket, which was a later design, if I am not wrong...
@ King Charles
I noticed, I HAVE got one pulley with a lip. That would be the idler. I USED to have an idler WITHOUT a lip and the tensioner had the lip. NOW I have the tensioner WITHOUT a lip and the tensioner WITH a lip...
@ King Charles
#2724
Yes I'm going back to the lipped idler pulley ASAP. I've pegged the chatter down to the idler pulley. I doused the belt in talcum powder & the noise stopped, so I'm banking on faulty belt or pulley misalignment. The Gatorback/my initial belt replacement didn't look to be the correct size when I matched it up against the original. It was an E-Bay purchase so whom truly knows if it was the correct size lol.
#2725
#2726
Today I replaced the Bank2 (Left) Upstream Heated O2 Sensor went to get my Emissions test. P1647 cleared and passed emissions tests. Then I went for a spirited drive up one of our great Colorado Canyon roads. I forgot how well that 4.0 can actually perform when in correct form.![Icon Eddie](https://www.jaguarforums.com/forum/images/smilies/icon_eddie.gif)
Once home without being arrested and a BIG smile on my face, it was celebration time with a Pappy Van Winkel's 23 year old Reserve Bourbon on my shelf - that is getting kind of pricey these days !!!
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Tomorrow, a drive in my '68 TR250 - drop head!![Icon Cool](https://www.jaguarforums.com/forum/images/smilies/icon_cool.gif)
Sometimes you see light at the end of the tunnel and it isn't a train ...
chris-jag (03-19-2018)
#2728
#2729
Scotlad (03-17-2018)
#2730
#2732
I just saw a Jaguar in my neighbors back yard today and went to ask him about it. It’s a 1997 XJ6 with 90,000 miles. He picked it up as a “tinkering” car. I can’t help but wonder if it was at least partly motivated by seeing the various Jaguars in my driveway over the years. It’s contagious you know. I might be a carrier...
The following 2 users liked this post by harvest14:
chris-jag (03-19-2018),
King Charles (03-17-2018)
#2733
#2734
I was asked a few weeks ago by an older bloke how much work my XJ8 requires and what I can recommend. I recommended an X300 as XJ6 from around 1996 with the then new Euro 2 Emissions.
Guess what is now new on the block... Silver XJ6 (not sure if 3.2 or 4.0l).
The following 2 users liked this post by Daim:
#2735
Reinstalled my OEM idler pulley after cleaning & lubricating it , along w/ a new belt. I think I've finally solved my serpentine noise.
Trying to remedy the last small knock I have in the rear end. I checked the wheels for play there was zero, so not the bearings. I crawled under & checked the exhaust which is loose on the driver's side, the side where the noise originates.
Anyone know if I can refresh the exhaust hangers or should I just replace them w/ new units.
#2736
![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
Where did you source your grill from ?
![Icon Clapclap](https://www.jaguarforums.com/forum/images/smilies/icon_clapclap.gif)
#2737
Do you still have the rubber grommets in the aftmost hanger and are the upper 2 bolts tight as a tooling combination can get on the 2 . Can't remember the combination by my muffler post was outside the hanger grommet and welded to the outside of the metal hanger as they couldn't figure the tooling out .
Requires removing the 2 bolts so you can bring out and slide the post into the grommet .
Where did you source your grill from ?![Icon Clapclap](https://www.jaguarforums.com/forum/images/smilies/icon_clapclap.gif)
https://www.ebay.com/itm/Jaguar-98-0...l/350550384828
Lady Penelope (03-17-2018)
#2738
I got your message and I had just walked in the door; been gone all day. I went out to the car and plugged the cruise control switch into my car to test it.
One picture is with the switch plugged in but the car off (switch not illuminated).
One picture with the car on and the switch illuminated.
One picture with the switch illuminated and turned on (red indicator light).
It appears to work perfectly fine.
King Charles (03-18-2018)
#2739
Saying good bye to an old friend may she have life as donor!
https://www.jaguarforums.com/forum/x...wheels-198531/
https://www.jaguarforums.com/forum/x...oolers-198530/
https://www.jaguarforums.com/forum/p...e-body-198533/
__________________
__________________
