What did you do to your X308 Today?
#2742
ericjansen (03-19-2018)
#2743
#2744
So, fitted my new (to me) belt tensioner, after exchanging the plastic pulley for a metal one (even though the plastic had a new bearing fitted).
Found out, that my nasty cold start squeal is the bearing from the AC compressor. So that is on the list to change.
Also had the first delivery of parts for my suspension alteration. Especially some Moog ARB endlinks... Went 'Problem Solver' instead of factory, as the last original Jaguar ARB endlink only lasted 2 years...
#2745
Daim ,
Check for the correct model number . Depending on your installation you may be able to remove the clutch without disturbing the compressor and it's lines
https://www.shopcenturyautoair.com/s...ing_BG405.html
The video is for a Denso 10PA - 15C and I believe yours is a 17C as a Jaguar # MCA7300AE
If you want to go ahead and overhaul the compressor other video and parts are on that site .
https://www.shopcenturyautoair.com/s...mpressors.html
#2746
#2747
There's a very good exhaust & suspension shop locally, I plan on going in tomorrow morning having them look @ my hangers & grease the u-joints while under there. Also getting a quote on installing the remote exhaust cut-outs (sinister chuckle) lol.
#2748
If you install them after the cat, before the center muffler, they will be loud, very loud.
My Utah friend just did that, now he drives around with the cutouts mostly closed, or just cracked open, as it is tooooo loud for longer than just that fun moment.
If you install them after the center muffler, it will will give a nice rumble, but never be too loud, maybe a tat too low.
Mounted there, you will not need an intermittent position, just full closed or full open.
There is also a significant difference in temperature between the 2 locations, plus some fuel lines.
Not saying where to put hem, to each his own, just that you know.
King Charles (03-19-2018)
#2749
One word of advice on the location of the cutouts, this my own experience, and a Utah friend I just helped.
#2750
#2751
The blue PU bushing halves were included.
BUT if your question was refering to the Moog part number for the entire endlink, it is K750225. That is as a kit with the blue PU bushing halves, the link and co.
And as Sean has yet again basically said I am a very unthankful person: A VERY warm and friendly thank you for the information regarding the bearing. I am VERY grateful for little tips regarding future jobs to do. Idon'to always say thank you, because it is a standard thing for me, that someone doesn't need to say thank you but is still thankful. So, just to make it clear: thank you again!
Sean B (03-20-2018)
#2752
#2753
Oh, and I understand the question as 'do you have the parts number for the bushes'...
But I correct my post, made sure that my intension was not to be a rude person and I express my thankfulness to a high degree.
Thank you for your tip and that a thank you never goes as miss. Especially since I don't see the need to express a thanks everytime, as I am always grateful for help...
#2755
Update :
Had the car on the lift everything in the rear looked snug & not to be knocking. Not sure where my noise is coming from. Noticed the exhaust system has been patched & banged around a bit, starting to leak. So I'm on the hunt for those components now if anyone has any sources.
#2757
Also how does one access the U-joints or zerks on these to lube them ?!
Edit
Productive day today, washer nozzle replaced, I can finally get the pollen off my windshield lol.
Undercarriage inspected on lift, caught an exhaust leak forming.
Since I'm a frequent flyer my paint shop quoted me $250 to respray my front bumper, going in Monday.
Cruise control switch installed & fully illuminated.
Edit
#2758
Went on a track day last weekend and a) removed a large amount of marbles from the all the tyres on Tuesday, also noticed a couple of stone chips on the bonnet.
Decided to apply some clear vinyl, yeah I know what I’m doing.
So after I come back from our trip down south the car goes in to have the bonnet repainted where I managed to rip off about a square foot of top coat to say I was rather mortified would be an understatement SWMBO seemed extremely calm about it.
