What did you do to your X308 Today?
Old 05-16-2018, 01:57 PM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
Well, the new daily driver arrived today...And it got my old XJ's number plate
  #2922
Old 05-16-2018, 02:08 PM
Carnival Kid's Avatar
Received 1,009 Likes on 613 Posts
cliveb (05-16-2018)
  #2923
Old 05-17-2018, 01:28 AM
King Charles's Avatar
Received 1,020 Likes on 741 Posts
Since my rear end howling/moaning is not present w/ "Traction Off" I will have my braking system inspected to ensure there's no sticking caliper etc. It's odd, I mean it goes from completely silent to howling as soon as the traction button's pushed.
  #2924
Old 05-17-2018, 02:01 AM
Daim's Avatar
Originally Posted by Carnival Kid
​​​​​​yeah, kind of a change, right? After spending around €7000 on parts and co in 3 years for the XJ I decided to use the rotten body to ditch it and get something cheap. I still have a Jag though -> 1989 XJ-S V12 Coupé. So I won't be that bad off
  #2925
Old 05-17-2018, 10:01 PM
CharlzO's Avatar
Finally decided to be unlazy and pulled the right rear to see why it was sitting a little funny, and hey, pretty sure the U-joint shouldn't move like that.. I have quite literally INCHES of play when I push on 12 O'clock. Parking for the weekend while I head to Newport, and then I'll have to see how bad a job this is going to be in the driveway when I get back home.
  #2926
Old 05-18-2018, 03:19 AM
davoid's Avatar
Default mirror dip reversing
Discovered that when I go into reverse I can get the kerb side mirror to dip 7degrees, allowing me to see where the rear wheel is while parking, and when I go out of reverse the mirror goes back to its set position.
Should have read the owners manual more thoroughly!
Carnival Kid (05-18-2018)
  #2927
Old 05-18-2018, 04:35 AM
Takeo's Avatar
Received 1,947 Likes on 868 Posts
I have no pic, but installed two chrome rear view mirror covers. Looks great.
  #2928
Old 05-18-2018, 12:04 PM
cliveb's Avatar
How'd you do that?
  #2929
Old 05-18-2018, 02:40 PM
Originally Posted by cliveb
How'd you do that?
Page 4-7 of Driver's Handbook:
"Door Mirror Dipping.
To give the driver a clear view of the kerb when reversing, the passenger door mirror can be dipped without erasing the memorized mirror position.
To Operate; With the selector switch in either left or right position, and reverse selected, move the mirror adjustment button rearwards and release, (one touch operation). The mirror will dip by 7 degrees. The mirror will return to its memorized position when reverse is de-selected, or the ignition switched to position "O".
The following 2 users liked this post by Carnival Kid:
cliveb (05-18-2018), LivewireRacing (05-23-2018)
  #2930
Old 05-18-2018, 06:10 PM
300 miles on winding coastline w/ zero noise in the rear ! Although it's nice this way, I must find out what makes it howl when I turn traction control on.
Plan on getting an alignment tomm. & have them check my brakes while they're under there.
ericjansen (05-18-2018)
  #2931
Old 05-18-2018, 07:51 PM
ericjansen's Avatar
Received 1,352 Likes on 927 Posts
So you took her off the selling-list again?
  #2932
Old 05-18-2018, 09:12 PM
Thumbs up
For now lol ?!
Was really frustrated when I posted that . But my domino theory w/ these has merit lol.
  #2933
Old 05-19-2018, 02:08 AM
Robman25's Avatar
Just spent the day thrashing around the back roads of Hawkes Bay in NZ. 6 special stages completed without any mishap. Brakes got a bit iffy towards the end of some of the longer stages, will post some video when I get home in a few days.
  #2934
Old 05-19-2018, 06:08 PM
Daim's Avatar
Before - inbetween - after
Just need to do the rear end and then the doors and then it is off to the dump with this 'heap 'o poo'
  #2935
Old 05-19-2018, 09:04 PM
Originally Posted by Daim
Before - inbetween - after Just need to do the rear end and then the doors and then it is off to the dump with this 'heap 'o poo'
Such a shame, but needs must.
There are others out there.
  #2936
Old 05-20-2018, 04:10 AM
Daim's Avatar
Yep. The rotten front air intake for the heater has let enough water inside to rust the floor. The more I look, the more rust I find. I'd say my car is a good example to go by for rust... I'll post a proper full 'rust check list' and I am sure many of the 'rust free' cars here will appear to have at least some rust...
  #2937
Old 05-20-2018, 09:14 PM
CharlzO's Avatar
Ordered parts to replace my half-shaft outer U-joint. Full plate hub puller, the U-joint, hub nut, and a ball joint press kit which should work fine, and also that darn O2 sensor that I need to replace. Just in case anyone is curious as to what clued me in as to my wheel issue:
Go ahead, laugh, because I wanted to lol
  #2938
Old 05-20-2018, 11:04 PM
Hmm, if I hear someone trying to bang on the doors trying to get inside the car while I'm driving down the road, I'll check the half-shaft ball joints first!
  #2939
Old 05-21-2018, 06:06 AM
Robman25's Avatar
This was the start of Targa Hawkesbay Mine was th last car out
Facebook Post
  #2940
Old 05-21-2018, 06:12 AM
Robman25's Avatar
http://https://www.facebook.com/TargaNZ/videos/1722592587826791/
Quick Reply: What did you do to your X308 Today?
