What did you do to your X308 Today?
#3681
I used an aerosol can of jhm pacific blue to respray my wing mirrors. It was only whilst I was in the airport car park that I suddenly realised how easy the covers are to remove : as I reversed into a space, the wing mirror somehow very slightly touched a concrete column and the cover popped right off. With this kind of encouragement, I thought what the heck let's give it a go!
Newly empowered by the first cover now sitting in my boot, I managed to wrestle off the other at my leisure, minus any helpful column type passersby.
The result is a fine pair of covers, now minus any damage whatsoever. I have been told that the orange peel like finish is a sought after effect that only a few can muster. I am winning already.
Once reinstalled, I noticed how the jhm colour appeared to be slightly different from the car itself and when I went to order another can I noticed that this is due to the car code being JHE, not jhm. Seeing as we don't have either the pacific or many sapphires in these parts though, I doubt anyone else will notice. I hope.
The End.
Wing mirror respray
The End.
Wing mirror respray
A.J.P (07-15-2019)
#3682
I started getting the "TRAC not available/ASB not available" message a couple of weeks ago. It was intermittent, then it got regular. I had cleaned my wheel speed sensors in the past, so suspected that it was time to service the ABS module as they are renown for solder joints going dry.
It is fairly easy to remove the ABS module, it would have been a lot easier if Jaguar had mounted the ABS unit 1/4" higher, and routed the brake lines just 1/4" further way, but even with these obstacles it was still pretty easy.
You just need to remove the two E30 torx screws holding the wiper relay bracket and move it out of the way. Remove the two 10mm nuts holding ground wires, and move the wiring out of the way. The ABS unit has a little flexibility in it and if you bend it back slightly you can access and withdraw the 4 E-5 torx bolts holding the Module.to the ABS unit. You need to pull the sliding latch holding the multi-pin connector to the module, and move it out of thr way. Then squeeze and wiggle the 2-pin power connector to the module and also move it out of the way. Now all you have to do is bend the brake lines a little and the module will slide out.
There are tutorials on the internet showing how to cut your way into the unit to repair the solder joints, and others showing how to cut a window into the unit to do repairs, but I opted to send mine to a specialist shop for repair and testing https://www.shop.modulerepairpro.com...2001_c1140.htm (Van Nuys CA) ($45 plus $13 return shipping)
The following 6 users liked this post by Carnival Kid:
chris-jag (07-16-2019),
cliveb (07-15-2019),
Iconoclast (07-15-2019),
LaserSVT (07-17-2019),
Tirefriar (07-18-2019),
and 1 others liked this post.
#3683
I had to do that in 2012 ~ 60K miles. I used ModuleMaster in ID. Not sure still in business. They rebuilt with a 5 year guarantee.
Got Jag dealer to remove & ship module to them & store my car & install it when it was shipped back to them. They originally had a MUCH higher price. I think it was triple the total price I ended up paying. When I mentioned MM, the SA had used them himself for one of his other vehicles (Motorcycle?) & agreed. My total cost was $555 including a dealer loaner vehicle.
I think they had the car > 1 week.
Anyway that completely fixed my "TRAC not available/ASB not available" messages. I had also cleaned my wheel speed sensors & think it made absolutely no difference.
#3685
Am I the only person that's never noticed the adjustable door buffers on each door and also on the boot? I've had this car over five years and found the crashing sound of the doors a little irritating throughout.
Problem reasonably solved now with a twist, but maybe new door seals would help even more.
Only £14 each! Part Hna5305aa
#3686
Jaguar X308 Adventures
So after doing all shocks & related rubbers,wheel bearings,tires,lubing springs,replacing bumper mounts etc. I was still left chasing a sporadic knock & creak from the rear driver side. I put it up on ramps & did the best I could do @ that height & found slop/play in the driver side rear axle area. I'm thinking either the prop/drive shaft bearing or the differential center bearing. So I'm setting up an appt.w/ the shop ASAP to rid my life of this damn creak lol.
#3687
Am I the only person that's never noticed the adjustable door buffers on each door and also on the boot? I've had this car over five years and found the crashing sound of the doors a little irritating throughout.Problem reasonably solved now with a twist, but maybe new door seals would help even more.
A simple and useful design, this info is deserving of the "Did You Know" thread.
chris-jag (07-20-2019)
#3688
#3689
My repaired TRAC/ABS module arrived back today.
It was a simple job to reinstall, and now no TRAC/ABS waning lights......perfect!
I can recommend "Module Repair Pro" in Los Angeles, their service is excellent.
I simply went to their site, (https://www.shop.modulerepairpro.com...2001_c1140.htm) filled out the online form with my vehicle details, address etc and submitted to them, as well as printed a copy to include with my module. The module fits neatly in a standard USPS small box wrapped in some bubble wrap and I mailed it on Monday morning USPS 2 day Priority Mail for $9.45. It arrived at Module Repair Pro on Wednesday at 11:35 am, I received an email from Module Repair Pro at 3:30pm that same day that my repair was complete and it was ready to be shipped back. It arrived this morning. A six day total turnaround.
The cost, $45 for the repair and testing of the unit, $9.47 to ship it to them, $13.44 to ship it back, so a total of $68.00.
I feel comfortable with this method rather than me cutting the unit apart, soldering the joints, then hoping it is fixed, gluing it all back together, putting it back on the car, and finding the TRAC/ABS light still comes on. Now I don't know if my repair was successful, or if there is another cause on the car. By sending it to them, they professionally repair it, and test it......I know the module is good.
If anyone suspects their ABS module needs attention do not be afraid of removing it, it is one of the simplest repair jobs on the X308, 15 minutes to remove, and 10 minutes to put back.
The following 4 users liked this post by Carnival Kid:
#3690
Installed a nice, used(no cracks anywhere) AC vent piece. How does one get the center wood grain to stay in place firmly? Mine comes off pretty easy, if you pry the lower right side with a flat head.
Also finishing up the led sidemarkers. Cleaning the lenses on the inside and polishing the lenses.
Old piece shown in pic number 2
LaserSVT (07-20-2019)
#3691
#3692
Edit:
From your pics I can see yours is cracked that will allow for ample play/loosening.
#3693
The following 2 users liked this post by LaserSVT:
King Charles (07-20-2019),
Z07Brandon (07-20-2019)
#3696
chris-jag (08-06-2019),
Z07Brandon (07-22-2019)
#3697
The following 2 users liked this post by nilanium:
ericjansen (07-26-2019),
Z07Brandon (07-28-2019)
The following 4 users liked this post by ericjansen:
Carnival Kid (07-26-2019),
King Charles (07-26-2019),
#3700
Well, X308 related ... I cleaned out my last storage room today, and organised the parts of the last 5 years.
I tend to keep a lot as everything is hard to get here, but enough is enough, I need some space.
Something I really hope I can make somebody happy with is the rear seat leather of my Vanden Plas.
Absolute new condition, Ivory (NED) with piping.
I would love to see it used, in stead of disappearing in the garbage.
Can skin them, normal posrage should not be that expensive.
