What did you do to your X308 Today?
#3702
Went out yesterday with the intent of backing it up on ramps to start looking at the evap system, thinking that if I could spot the culprit, might make it easier to sell without an engine light....
and promptly snapped the shift mechanism due to a frozen transmission cable. It had been a little rusty prior, but it always freed up after minor effort. Not today. Snap. So the little white piece that feeds the linear switch and notches into the shift lefter snapped in pieces. I got under the car today to try to remove the cable, and have run into a snag where the nut on the end of the shift bracket on the transmission case is just spinning. Not sure how easy that's going to be to maneuver any thing into there to try to keep it solid, so I gave up for this weekend. Pulled the for sale sign off, since at this point, it's no use taking less and less just because of the issues it's creeping up with. Sad part, is I spent most of yesterday replacing calipers and pads and issues with my son's mustang, and I still have to get the Sentra up in the air so I can try to get to the crank position sensor sometime this week. Wanted to sell the Jag specifically because I was sick of having to work on so many things as it is, and now I end up having to work on it anyway even to try to get rid of it. Not a fan this weekend..
#3703
Been dreading this job!
No other way keep cutting till good metal!
Had to rebuild jacking point !,
Starting rebuild
Easier in pieces keep the contours of the floor.
Came out all right! I'm well pleased!
That's the drivers side done!, now the other side! Looks to be about the same amount of work!.
The following 4 users liked this post by len1957:
#3705
Oil change, S/C inspection and transmission fluid level inspection on the XJR. I was having some hesitation and scared to death I had succumbed to the dreaded curse of daring to opening up the MB 5G tronic to change the fluid and filter, even though fluid wasn't too dirty and no metal shavings in pan. However after the oil change and adding some techron to the tank running smooth as ever. Transmission fluid is spot on at temperature with no leaks, shifting smooth with no hesitation.
#3706
Shop called & the "knuckle" on that side has a failing bearing/bushing.
I'm going to get a better explanation in writing when I pick it up this week. Good news is they found the damn coolant leak that 2 other "shops" couldn't locate. Was losing 3-5 ounces of coolant every 500-600 miles with no visible clues. It was a hose on the bottom side of the engine.
Anyone have a large printable diagram of the rear hub/spindle/knuckle I can take & get them to elaborate better. As I think terminology w/ them being lifelong southern guys is adding some murk to the picture. "Bushings & knuckle" threw me for a loop over the phone.
Glad the nuisance coolant leak's being addressed though.
#3707
#3708
#3709
They're confident they can do the procedure per the forum thread. So I'm going to order the tapered bearing & components & have an appt. for the 20th to get it done.
The coolant leak was heater hose/NCA3945CD underneath the intake, they also found some missing bolts on the intake boot & addressed that.
Jag forums strike yet again w/ clutch esoteric info. !
The following 2 users liked this post by King Charles:
chris-jag (08-25-2019),
Z07Brandon (08-08-2019)
#3710
The following 5 users liked this post by LaserSVT:
Addicted2boost (08-09-2019),
King Charles (08-13-2019),
Lady Penelope (08-11-2019),
Z07Brandon (08-09-2019)
#3712
I'm not usually a fan of stickers and decals, but this one caught my eye and I thought I'd try it.
https://www.ebay.com/itm/Jaguar-Chro...AAAOSw4UpckWhQ
The decal is a quality item, made of chromed metal with an adhesive backing. Simply peel the metal decal from it's backing, place it where you want it, then peel off the top transparent sheeting.
If you look around inside the car the only place it actually says "Jaguar" is on the cassette tape door, (oh, and the clock) so I thought this one belonged on the passenger burled walnut airbag panel. I think it looks really nice and I think it adds something to the car (IMHO of course)
The following 3 users liked this post by Carnival Kid:
#3713
Nice touch Carnival Kid,
I had ordered them before from Poland (search on site of ebay Germany), they also have besides the 60mm,an identical,more subtile 30mm variant.
For European owners :
https://www.ebay.de/itm/122778803457...&s=ci&mail=sys
#3714
#3718
The following 6 users liked this post by Carnival Kid:
chris-jag (08-19-2019),
cliveb (08-18-2019),
ericjansen (08-18-2019),
King Charles (08-17-2019),
neurojag (08-17-2019),
and 1 others liked this post.
#3720
Managed to wiggle the dash lights that sit in the air con unit and get them to light up again. Saves buying the led versions.
Dash board bulbs
Back of air con unit
Also welded the rear wings, just in time for the weather.
Grind out the rusty bits , weld in new material, grind down the welds, skim with body filler to perfection hopefully, prime, paint.
Quite a lot of work and I still need to go into the boot and make sure the inside has rust converter where it needs it. Sealer is in the way everywhere though.
Lots of grinding helps improve the welding :-)
Dash board bulbs
