What did you do to your X308 Today?
Old 08-20-2019, 08:12 AM
King Charles's Avatar
Received 1,020 Likes on 741 Posts
Dropped car off @ 8 am EST, operation creak removal is underway, this has been a thorn in my buttocks for 3+ years now lol.
  #3722
Old 08-20-2019, 03:59 PM
LaserSVT's Avatar
Sent the old wheels out to be refinished and repainted in a custom color. Figured while they were off I would freshen up the brakes a bit. Pads/Rotors only have 2k miles on them but calipers were ugly. Figured the silver would go nice against the new wheel color.
The following 4 users liked this post by LaserSVT:
Carnival Kid (08-20-2019), chris-jag (08-23-2019), ericjansen (08-21-2019), King Charles (08-21-2019)
  #3723
Old 08-21-2019, 07:11 PM
LaserSVT's Avatar
The following 2 users liked this post by LaserSVT:
chris-jag (08-23-2019), Sweden Mattias (11-08-2019)
  #3724
Old 08-22-2019, 01:21 PM
Car's back w/ new tapered/pivot/hub bearings installed, 4 wheel alignment, my 3+ year odyssey to find & remove my last rear end noise is now complete lol. It's amazing how much effect those small bearings have, It's so much smoother on curves that shift weight to the driver side. I could @ times feel that rear wheel bobbling,not anymore, did I mention the damn creak is gone ?! lol.
Kudos to the braintrust of Jag Forums for the images & inside info. I actually printed diagrams & a thread from here & gave to the shop lol.
  #3725
Old 08-23-2019, 02:11 PM
Count Iblis's Avatar
Rear wheel bearings changed on rear left side.
New Deeper cored fabricated Aluminium Intercooler radiator fitted behind front grill
New Starter motor fitted and all earths cleaned throughout car- seems to have rectified an illusive no start problem I was having
TPS connector/harness ends cleaned up and re- fitted- to solve an electrical gremlin.....
  #3726
Old 08-23-2019, 03:30 PM
chris-jag's Avatar
Default One thing leads to another
Only wanted to check the lower wishbone bushes, but in the process found the front springs were either broken or rust welded into the spring pan. I think I'm the first person to remove the springs in the past 200k miles.
I keep having to remind myself to use this tool as it's the only one that truly works Need to remove the brake disc and shield, but it's worth it
Rust around the bottom front spring... Doesn't look good...
Did you know that after 200k miles, these two parts become one 😁
Not a nice picture! Spring pan and front spring combined
Spring pan waiting for the die grinder
Por15 metal prep applied
Finally after a couple of coats of por15
  #3727
Old 08-23-2019, 04:55 PM
Carnival Kid's Avatar
Received 1,009 Likes on 613 Posts
Holy Moly, that British weather is caustic!
chris-jag (08-24-2019)
  #3728
Old 08-23-2019, 05:12 PM
Washed Jaggy-O today & had a casualty, lost half a center cap/badge lol. Oh well just an excuse to replace the old w/ new !
chris-jag (08-25-2019)
  #3729
Old 08-24-2019, 01:57 PM
chris-jag's Avatar
Yeah, and totally like hard work for the unsuspecting among us!
Job completed today, thanks to British Parts sending the springs etc, post haste.
I did find it slightly difficult to achieve 150Nm on the wish bone bolts whilst laid on my back almost sandwiched by the car sitting on the ramps, being scorched by the sun every time I poked my head out!
Never again!
  #3730
Old 08-24-2019, 04:10 PM
Chuck Zalinski's Avatar
Smile Changed the oil and pressure sensor
The low oil dash light had been going off and giving me stress. Only after warming up and only at idle but it took away from my enjoyment driving around to see it go on.
I was worried about the oil pump going bad, but figured to replace the oil pressure sensor first to see if that was the problem. It's an $8 part and easy to fix. Right next to the oil filter.
Well that fixed things. The old sensor definitely had some gunk blockage. Now I have new oil and lower stress worrying about the oil light. Feeling happy.
The following 2 users liked this post by Chuck Zalinski:
Carnival Kid (08-24-2019), chris-jag (08-25-2019)
  #3731
Old 08-25-2019, 04:09 PM
chris-jag's Avatar
Is that a spray on silver finish? I tried the brush on stuff and it really doesn't look as good.
  #3732
Old 08-25-2019, 04:19 PM
chris-jag's Avatar
Wasnt really expecting to have to do much of an alignment after installing new springs, but I was very wrong. Couldn't really drive the car over 20mph without it. It was miles out.
So here's my tool set: string, 13mm wrench, 22mm crowsfoot, and a tape. 3mm toe in as a rough home alignment gives a very nice result.
Don't forget the plastic bags under the front wheels either. Makes the whole job so much easier.
Clamp that steering wheel down too somehow.
Home alignment tools. String & plastic bags out of shot
  #3733
Old 08-27-2019, 09:22 PM
Well guys China's decided to knock off the center caps @ a big discount($20 per set) they look like proper clones w/ the video. I may order some & take one for the team for evaluation purposes .
https://www.ebay.com/usr/smartool_au...p2047675.l2559
Edit :
Mine separated where the color partially came off like film in spots, so I painted w/ some craft acrylic paint & reattached w/ silicone. I don't expect that to last & will replace all 4 w/ new ones when I have the tires rotated in about 3K miles.
The following 2 users liked this post by King Charles:
chris-jag (08-28-2019), neurojag (08-28-2019)
  #3734
Old 08-28-2019, 04:20 PM
neurojag's Avatar
Thx for the tip King Charles, i also bought the grey/silver ones (as reserve...)
  #3735
Old 08-28-2019, 07:01 PM
Post your findings once you receive them.
Phase one of "Operation Engine Bay Revival has arrived", new weather stripping for the engine cover panels.
  #3736
Old 08-29-2019, 02:28 PM
Stu 1986's Avatar
Today I sold my X308, she goes to her new owner on Sunday. This ends 11 years of continuous X308 ownership and 3 versions of the car. I am fond of the car and I’m sad to see her going but it’s time to move on.
  #3737
Old 08-29-2019, 02:40 PM
Sorry to see you go Stu, hope your new rides are trouble free and full of fun. CK
  #3738
Old 08-29-2019, 07:03 PM
Z07Brandon's Avatar
Out curiosity, does anyone know if the non Brembo xjr and xj sport use the same brakes? Pads, rotors and calipers all the same?
  #3739
Old 08-29-2019, 07:10 PM
ericjansen's Avatar
Received 1,352 Likes on 927 Posts
Originally Posted by Stu 1986
..... but it’s time to move on.
Thanks Stu, for everything you did for me, and for the forum.
chris-jag (09-01-2019)
  #3740
Old 08-30-2019, 03:48 AM
davoid's Avatar
Maserati? Panamera?
Quick Reply: What did you do to your X308 Today?
