What did you do to your X308 Today?
Old 11-19-2019, 08:47 PM
ericjansen's Avatar
Received 1,352 Likes on 927 Posts
Originally Posted by David N. Warner
I have a lot of extra parts since I'm going to have the old one towed away....
That sounds like a rewarding project .. and need pics .
If you have the interior rear view mirror available, I will be interested.
Don't mind if leaking, I will do the Sybesma route.
Yellow connector.
  #3902
Old 11-19-2019, 10:26 PM
King Charles's Avatar
Received 1,021 Likes on 741 Posts
No more eyesore, one clip & it's gone lol. Hopefully I can get the new unit in soon.
  #3903
Old 11-20-2019, 06:29 AM
euphonium01's Avatar
Hi Eric, tried the wheels on as they are, they went on but as you stated they were tight. The clearance at the top seemed OK, though I didn't want to go out on a road test and risk running them not being able to take them back to supplier.
They only just cleared the arch at the back and front, by about 2.5cm steering ahead, but 1cm+ on steering lock.. too close for comfort.
Although they went on and cleared, the front of the car was sat well high. Tested against the 16" on one side and 19" on the other, there was 2" or more difference in height.
Off to try and get them changed for the 245/40s, wish me luck.
Many thanks for the warning before I fitted to the car..
Paul
  #3904
Old 11-20-2019, 12:09 PM
LaserSVT's Avatar
  #3905
Old 11-20-2019, 02:20 PM
Carnival Kid's Avatar
Received 1,010 Likes on 613 Posts
What's the story behind the motor mounts Laser?
Are those URO mounts that have failed, and if so after how long, how many miles.....?
  #3906
Old 11-20-2019, 04:49 PM
LaserSVT's Avatar
Nope. Stock mounts, 18 years old. Never had an issue with Jag URO parts. BMW yeah but Benz, Audi and Jag they have been good to me. I asked the guy I sold my 98 XJR to about 7 years ago now if they were still good. He said he goes to the drag strip every month and has yet to have any issues.
Story is i got on the car really hard for the first time ever last week. Lit the Michelins all the way till 3rd gear. next day the car was vibrating and i thought "Hmm, wonder if the engine mounts are going out". Latter that day I had to pull out in traffic and when I let off I heard a loud "thud". Brought it back to my shop, popped the hood, loaded the engine and saw it lift higher than the hood if it were closed! Put it up in the air and the driver side mount was laying against the steering joint. I cant believe I didnt hurt anything. So 90 minutes latter we had new ones in and shes as happy as can be.
Carnival Kid (11-20-2019)
  #3907
Old 11-21-2019, 07:05 PM
Turned out I was very lucky again in returning the tires I had wrong! I took back the 255/45/19s, and replaced them with the 255/35/19s which I understand were original fitment? The added bonus was the tires I had on hadn't even been put on the car (still had the manufacturers sticker on them) so the guy was happy to change the tires for the correct size with no charge.
Big thanks to ericjansen for his timely intervention, as usual, he was spot on with his advice. and potentially saved me a fortune.
Paul
The following 2 users liked this post by euphonium01:
ericjansen (11-21-2019), Vegas_Jag (11-21-2019)
  #3908
Old 11-21-2019, 08:12 PM
ericjansen's Avatar
Originally Posted by euphonium01
.... and replaced them with the 255/35/19s which I understand were original fitment?
You will be fine; your car will have the same wheel / tires as the XJR100 was fitted with, a lot of people here will envy you, including me ...
Great it worked out fine.
  #3909
Old 11-21-2019, 08:51 PM
Vegas_Jag's Avatar
Pix please!
  #3910
Old 11-22-2019, 08:08 PM
My overhead console odyssey is still ongoing lol. So after switching my old good light module to the newer wood unit the screw tabs broke but the middle screws were seemingly enough to hold it. Well it's too loose apparently as I'm getting erratic light performance & buttons have too much play/not pressed tight enough to module. Of course the wood unit's light panel has perfect screw mounts but also has 2 out sockets so no good. I'm nearly tempted to bust out the soldering iron & take the donor module apart & try to repair the 2 bad sockets. My solder skills are primitive novice for sure lol.
I see a few light modules on e-Bay for sale w/ perfect screw mounts but no one has tested the damn lights ?! What's the point of selling a lighting module if you're unsure the lights actually work ?! Mind you my overhead console is still mounted w/ the engine bulkhead cover fastener lol.
  #3911
Old 11-22-2019, 09:30 PM
Vegas_Jag's Avatar
I'm going to yard Sunday, there's a console there,ill try to get it if you like?
  #3912
Old 11-22-2019, 09:33 PM
Originally Posted by Vegas_Jag
I'm going to yard Sunday, there's a console there,bill try to get it if you like?
Appreciate it but I just scored one for $10 he claims it's 100% tested & has 30 day returns so it's no risk.
Vegas_Jag (11-22-2019)
  #3913
Old 11-25-2019, 07:28 AM
Fitted Cruise Control. My 1998 is the early vacuum type operated Cruise Control, but couldn't find much info on how/where all the vac pipes went. Got the information off the guy who removed it from donor vehicle.
Just in case it helps someone else, I drew a small diagram..
I already had the switches from a previously fitted 'part wood' steering wheel, the brake switch came with the solenoids, vac canisters, and vac pipes.
The connections to the solenoids were already there on the right false bulkhead next to the brake servo (RHD), the connections are color coded to the solenoids.
Hardest part was fitting the brake switch, the wires were already there for that as well!
Worked a treat first time
Paul
The following 3 users liked this post by euphonium01:
chris-jag (12-03-2019), ericjansen (11-25-2019), King Charles (11-28-2019)
  #3914
Old 11-25-2019, 04:34 PM
Z07Brandon's Avatar
Sold the 02 Sport today
In order to fix this
The following 3 users liked this post by Z07Brandon:
ericjansen (11-25-2019), King Charles (11-26-2019), Vegas_Jag (11-25-2019)
  #3915
Old 11-25-2019, 05:38 PM
ericjansen's Avatar
Originally Posted by Z07Brandon
Sold the 02 Sport todayIn order to fix this
Saw the pic before, but sweeeet .... those wheels look so good on that car!
Succes!
Z07Brandon (11-25-2019)
  #3916
Old 11-25-2019, 07:17 PM
Z07Brandon's Avatar
Thanks Eric. Time to look for an engine and possibly buy an lsd at the same time.
  #3917
Old 11-25-2019, 10:17 PM
Night time maintenance wash, oh so sweet lol.
  #3918
Old 11-25-2019, 10:21 PM
Z07Brandon's Avatar
Awesome pic, and car looks sharp!
King Charles (11-25-2019)
  #3919
Old 11-26-2019, 12:48 AM
Thanks ! BRG's so multi-faceted depending on the lighting. I get a myriad of greens in bright/direct natural light. Dusk & night are my favs though she goes molten black.
Also getting my nemesis/3rd brake light installed tomm. morning we should be sitting pretty for the upcoming holiday !
Z07Brandon (11-26-2019)
  #3920
Old 11-26-2019, 06:48 AM
davoid's Avatar
Took J-gate assembly apart and put it back together. That's because, upon stopping to park and momentarily forgetting about J-gate configuration I shifted into 2 from Drive, possibly more quickly than I should have. Then it wouldn't go into or past Drive. No clue why. Also that meant I couldn't get key out. Disconnected battery, still wouldn't budge but at least got key out. Took the top off the J-gate and was able to get the thing back into Park. Reassembly, reconnect battery, start, drive and shift no problems. Very nicely in fact. Sigh. This has given me grief before so I must remind myself to use brake and not use gears unless going down a steep grade, and even then make the manual shifts very gently.
"Other than that Mrs Lincoln, how did you enjoy the show?"
Quick Reply: What did you do to your X308 Today?
