Sold my back up x308 today I didn’t need two since I’ve got a s type. Made 500$ off its so definitely worth it. Plus I got to drive a little nicer x308 than mine for a while
Probably best to just get the front fluted grill, it is the most important, most impressive, most noticeable upgrade............we don't need no stinkin' rear fluted trunk bar!
Had this annoying situation with the right side (driver's) door not locking or opening when I used the fob, all the other doors and boot worked fine off the fob. If I used the key, all 4 doors and boot locks worked perfectly.
I decided that while the 'lockdown' was in force I would take the time to have a go at the problem, I started with the Electrical guide, which is usually a no no for me! Behind the left Heelboard, there's a Violet Relay with Slate/Green wire from it that goes over the drive tunnel to a 'Splice Header' (sort of connector block, 1 Slate/Green In - 4 Slate/Green Out) the Splice Header is behind the right Heelboard, the 4 wires coming out are all Slate/Green and 1 goes to each door actuator.
I did a continuity check between the Splice Header and the connector block (CAB-4) in the bottom of the door, there was no continuity. I traced the loom in the bottom of the door to behind where the Speaker opening is, and found the Slate/Green wire. I tugged at it to get some slack to fix to it, and it simply pulled out altogether, about 10" of it, it had broken inside the rubber protection boot between the door and 'A' Pillar.
It was a bit of a struggle to get the protection boot back far enough to re-solder the wire, but I got it eventually and it now works a treat! While the protection boot was pulled back, I took the time to check all the other wires in the loom coming through into the door, and they all seemed fairly new!
I'm really happy I got the problem fixed, but the only reason I can think of as to how it became broken is the constant flexing when opening and closing the door, and being the driver's door it gets the most use! The only thing is that none of the other wires, at that particular place, showed any kind of damage?
Paul
Glad to see you healthy around Paul.
The trunk hinge has the same problem, mostly just the lighting wire which breaks from the whole bunch ... Jaguar gremlins I suppose ...
Replaced no8 coil. Rough starting, goes away when warm. Sometimes. I reckon I've done about 6 over 2- 3 years. Is there something I'm doing wrong?
I have now replaced 7 of 8 coils over 10 years.
Each time I have the rough idle & restricted performance that comes & goes & the OBD-2 reader shows cylinder misfire & the # of the cylinder change depending on which coil.
Last done for coil #8 1 year ago @ 90K miles.
It was Cyl # 8 so got DTC P0358, Ignition coil H.
Time b4 that was coil #6 & had several codes.
P0306 cylinder 6 misfire detected, generic code
P1314: misfire catalyst damage bank 2 engine mechanical fault
P1316: Misfire exceeds emissions
So I am finishing up the remaining small issues which developed over a year of storage.
The eBay gear-knob I bought some years ago was showing it's age, so I stripped it, then put about 10 layers of clear coat on it.
Needs to dry and harden, but it looks fantastic.
Eric, you're a genious! Following your comment about the trunk hinge I thought I would best check, after removing the plastic cover I found another broken wire. It was Red/Yellow which appears to be the Trunk Switch?
Re-soldered that one too, and now the 'Boot Open' warning seems to have stopped playing up (I did a different post about this warning appearing everytime I opened and closed the Trunk).
Once again, thanks Eric, and for your kind words... feeling better each day
Paul
Wow, I'm in love with your car. BRG is my all time favorite color. Looks amazing. How do you like the Colonite? I've heard of it being used in detailing cricles for years but never tried it, have been using Meguiars 21.
Love it, best unheralded wax in the game IMO. Easy on & off w/ supreme slickness, stellar shine & super durable.
