What did you do to your X308 Today?
#441
rear shocks, finally
I have had these brand new Bilstein rear shocks sitting in the garage since May. Finally took it to the local Independent (Abacus Racing) and had them installed (looked to do this myself, but just too old to break some of those bolts loose).
Cost $450 in labor: two bolts very hard to break loose, old shocks were still usable, but the bushings, top and bottom, were gone as were the top spring retainers. No more clunk and rattle and much improved handling.
That completes all the work I knew I had to get done when I bought the car in April. Replaced shocks and pads all around, upper front shock and sway bar bushings, drive belt and tensioner, water pump, thermostat and housing, hoses, plugs, secondary tensioners, new tires on the rear, AC recharge, air cleaner; monthly cleaning of MAF sensor, throttle plate and bore, Gumout for injectors. Thanks to excellent advise on this forum, Did all the work myself except rear shocks, supra, and tire balancing and alignment. Wife has become a pro at pumping up and holding the brake during bleeding ops. Lots of bonding! Now drive it, enjoy it, and wait to see what breaks. Toying with replacing the headliner (found a guy here who will do it for ~$450).
#442
I installed stainless steel brake lines and slotted and dimpled EBC rotors
I installed stainless steel brake lines and slotted and dimpled EBC rotors.
The brake lines improved my brake pedal feel, but I am still having the "problem" of the pedal sinking a little....maybe I have an internal leak in the master cylinder?
We did bleed the brakes carefully and I am confident there are no bubbles.
The rotors do make some wind like noise when driving, but I think it is worth it for the extra braking. At some later point I am going to fabricate ducts to the rotors.
#443
NICE!
I noticed a very firm pedal when I installed a set of Goodridge G-Stop lines on my old show car.
How loud is the "wind noise". Can you hear it when the windows are up?
Dunno if I would want that...
Cannot wait to see your brake rotor ducts!
I remain here sedately, living vicariously through your modification posts
Stewart
#444
NICE!
Stewart
Stewart
The wind noise is significant enough you can hear it with the windows up, it does detract from the quiet "Jag experience" and I would not do them again for this reason. There is a definite cost to adding these, the extra braking does not come for free. I will not be adding these to my XJ8. If I were to "need" more braking, I think swapping to bigger flat rotors and ducting them would be the better way to go. Not all my mods turn out as I would like.
I'm also thinking about swapping back to my original catalytic converters when smog time comes. Since the nameless cats cannot pass at road speeds in California, I'm rethinking if they are worth the approx 10 hp gain. I'm kind of leaning toward the super stealth approach vs the healthier sounding engine these days. They really do improve the sound of the car though...I have plenty of time to think about it.
#445
I think the o-rings in my master cylinder are leaking a little and the fluid may be leaking back into the reservoir.
Ahhhh, the California Smog Tests.
I don't miss them a bit!
Stewart
#446
#447
#448
This week...
Here is what I did this week:
-purchased a complete set of interior wood.
I noticed that some of the wood panels are turning milky. Right now it's just the driver's door wood and the gauge cluster surround. However, I know all the panels are probably going to do this.
-purchased a chrome metal leaper.
I want to see how it looks on the dash. It is a little over 6" long. If it looks good on the dash, I'll install it, and post up some pics.
-Bought a NOS green reversible Jaguar Racing Jacket.
Okay, it's for me, and not the car. It's pretty cool! Can't wait to wear it!
-Ordered the foam for my tool kit idea.
Hope to get this done soon and post up some pics of this compartment utilized.
-ordered a Paramount Performance Stainless Steel Cat-Back Exhaust System.
-ordered a Paramount Performance Stainless Steel Mesh Bumper Grille.
These parts look absolutely beautiful! Can't wait to get them and install them!
FINALLY scheduled a pro to fix the tear in my rear lower seat cushion. I tried a kit to fix the tear in the leather, and the glue did not stick. I've NEVER had good luck with any DIY vinyl or leather repair kits. Oh well.
I touched up any and all imperfections in the interior with AGD/Oatmeal dye. Since I spilled an entire Starbucks latte in the passenger seat last week, I went ahead and dyed the lower front cushion. It came out so good, that I went and redyed the entire seating surface on the drivers seat. Man, oh man, do my seats look B E A U T I F U L ! ! ! !
I'll be vacationing in Southern California this week, so I won't get much done on the XJR until I get back.
However, when I do get back, I have a lot to do!
Stewart
Stewart
#449
Get a real OEM tool kit for your Jag, you can find them on British Ebay sometimes, that is where I got mine. They were not installed in cars for the US market.
Vector
Elmo1544 (04-27-2021)
#450
The Leaper leaps from right to left... lol
I dunno.
I like how my tool kit is working out.
I KNOW I can make better use of the compartment than buying an overpriced marginal tool kit.
Stewart
#451
It's kinda for my car, right?
I ordered this shirt:
From THIS eBay UK Vendor.
Also ordered this decal:
Thought they were pretty cool and relevant.
Stewart
Stewart
#452
I replaced my front rotors and pads. I went with Akebono pads for the reduced brake dust. Rotors were Centric. $265 total from Tire Rack. 2 hours time. Followed the 'How To' link and all went well. Next up: front shocks and upper bushing, sway bar links and bushings.
Dan
2000 platinum XJR
Dan
2000 platinum XJR
#453
#456
#457
Front screen washers repaired
Hi, My front screen washer jets were spraying less and less water on the front screen since I owned the car. Eventually they stopped working all together. I was thinking clogged tube or furred up jets.....I was thinking I'd have to dismantle and strip out the tube etc...however, a quick look-over and I discovered that the black washer-tube that comes out of the front scuttle panel and into the wiper arm was almost severed, hanging on by a thread. I cut it off, pulled off the wiper arm plastic nut-cover and re-attached the cut end of the tube to the little white tube-joiner under the plastic cover and reassembled the cover onto the wiper arm...job done, took about 2-3 mins...Fully working screen washer jets....Really pleased. Allan
#458
Finally finished blacking out my chrome trim around the windows, installed black/chrome union jack badges where the 'V8' emblems were, removed my rear view mirror to send our for repair, fixed my cup holder so it won't pop open over every other bump, began removing window tint first installed when the car was new.
Dan
2000 platinum XJR
Dan
2000 platinum XJR
#459
Washers
#460
PS - Just read your post again..... is the black joiner that comes out of the scuttle top broken off? Allan
