What did you do to your X308 Today?
Old 04-27-2024, 08:37 PM
Philip_A's Avatar
Fixed the gearshift illumination.
Fiddly bulbs.
03_jaaag (05-10-2024)
  #4922
Old 04-27-2024, 11:38 PM
24ounce's Avatar
smoked some of the lights and markers, yellowed the fogs, still have the mains and rear to do
  #4923
Old 05-10-2024, 06:57 PM
Philip_A's Avatar
Finally got round to putting the center console back together.
Everything fits a bit better with more clips than there were before.
Phil
  #4924
Old 05-12-2024, 08:16 AM
Philip_A's Avatar
Go figure. Some of the previously working bulbs, now disturbed, ceased to function. Guess that all comes apart again. (TSC and Sport now don't glow).
Phil
  #4925
Old 05-24-2024, 08:51 PM
nilanium's Avatar
I did something that I've wanted to do ever since I did my first drive in an x308 XJR... took it on a big road trip to Skyline Drive! Start to finish, and touched on a couple dozen miles of Blue Ridge Pkwy, and back up to the north end of Skyline over the course of a few days. And the car took it FLAWLESSLY. Well, except the pesky front-end vibration that I can not figure out for the life of me, and the trans shifting a little harsh (issue with this Ebay trans I haven't sorted yet), everything else worked perfectly - even the AC has held up blowing ice-cold since the refresh last summer. Only took me 7 years to get around to doing this...
The following 2 users liked this post by nilanium:
neurojag (05-25-2024), Philip_A (05-25-2024)
  #4926
Old 05-24-2024, 09:18 PM
Quadcammer's Avatar
Phil
Wow...that's a look. Seems like it would be distracting
  #4927
Old 05-25-2024, 12:01 PM
Philip_A's Avatar
Yeah, that radio just goes into a BRIGHT AS THE SUN IN ALL THE COLORS demo mode when you connect the battery.
I've since got it connected up and set so it's much more dim in a much more modest green.
Today though, I got in the mail a brand new (to me) fuel filler cap bowl.
It's in superb condition. That'll stop it leaking into the trunk.
I've lost my metric wrenches...
The green is better.
Phil
  #4928
Old 05-25-2024, 12:36 PM
Addicted2boost's Avatar
Received 1,089 Likes on 839 Posts
Phil, there *might* be a chance you’ll need to slide the fuel tank rearward to replace that. If so, you’ll need to have as little fuel in the tank as you can then disconnect the fuel lines underneath *first*. I would advise against pulling the filler neck downwards to replace it as the neck can crack at the tank. The 8mm nuts are in a bit of an inaccessible location so be patient when replacing this.
  #4929
Old 05-25-2024, 01:17 PM
Philip_A's Avatar
The new filter bucket got put in, because it's a UK part I pulled the fuel sticker off the old one, cleaned all the dirt and old adhesive off the back, applied new and stuck it on the new one.
Much better!
Phil
  #4930
Old 05-25-2024, 01:18 PM
Philip_A's Avatar
The new rubber part was flexible enough to squash up and over without having to move the tank or filler neck at all. It all went in with the minimum of fuss, I was quite surprised.
Thank you for the words of caution there though.
Phil
  #4931
Old 05-30-2024, 10:53 AM
Philip_A's Avatar
Looking at the fault the transmission valve body develops at high miles. Guess I'll drop the pan and inspect that, see if it's been changed or if it needs repair or replacement.
In other news, just bought a replacement engine.
Phil
  #4932
Old 05-30-2024, 11:08 AM
RandyS's Avatar
I finally got the Upper O2 sensor replaced. I was a bit afraid to drive the
Duchess, because I had learned the Catalytic Converters could get saturated
because of it. However, all is well now, and it is great to drive her whenever I
please again.
Philip_A (05-30-2024)
  #4933
Old 06-03-2024, 04:16 AM
Takeo's Avatar
Received 1,949 Likes on 870 Posts
This morning, I kissed my X308.
The following 2 users liked this post by Takeo:
Ken Cantor (06-03-2024), neurojag (06-03-2024)
  #4934
Old 06-08-2024, 01:36 PM
Philip_A's Avatar
Repaired the headrest and cushion tilt on the driver's seat, fixed the tag light housings, cleaned up and fitted some LED festoon bulbs that don't get so warm.
​​​​​​That'll do. Happy with those.
Phil
Ken Cantor (06-09-2024)
  #4935
Old 06-08-2024, 05:28 PM
Philip_A's Avatar
Also repaired the broken wire in the lighting harness.
That's a poor design. No strain relief.
Either way we now have parking lights. Nice.
Phil
  #4936
Old 06-09-2024, 01:04 PM
Philip_A's Avatar
Sigh. The plastics are so brittle. Thankfully super glue is good for it.
Still, it did go back together and now works.
Last one to go fix is the turn signal repeater on this side. That's a wiring fault.
Phil
  #4937
Old 06-09-2024, 04:18 PM
Philip_A's Avatar
Rewired the side repeater.
The wiring that had been used was all corroded to powder.
Better now. Got the wrong wattage bulb in the other side so I'll swap that out.
Phil
  #4938
Old 06-10-2024, 09:56 AM
Hooli's Avatar
I drove mine to work over the weekend & thought, yet again, that I really need to wash it as there's mould growing in various places. Trouble is car washing weather is also motorbike riding weather...
  #4939
Old 06-13-2024, 02:02 PM
Silverjag0's Avatar
Replaced the clock bulb I believe I should have used 4.2 wedge led but I used t5 led it doesn't fit properly you will need to sand the t5 socket to fit the clock but it's working fine here's picture ice blue led bulb
Philip_A (06-13-2024)
  #4940
Old 06-13-2024, 02:18 PM
Silverjag0's Avatar
Quick Reply: What did you do to your X308 Today?
