What did you do to your X308 Today?
Old 06-13-2024, 11:49 PM
24ounce's Avatar
Set the wheels out to the fenders and added a rear lip
  #4942
Old 06-14-2024, 06:09 PM
Philip_A's Avatar
I received an engine.
Phil
  #4943
Old 06-18-2024, 08:14 PM
Philip_A's Avatar
Made a rig up to lock the crank.
Must've put about 800lbft on it and it just told me nope.
Plan B beckons
JagSter63 (06-18-2024)
  #4944
Old 06-19-2024, 07:12 AM
Addicted2boost's Avatar
Received 1,089 Likes on 839 Posts
Phil, if you have a full size floor Jack, remove the Jack handle and put it over the breaker bar for more leverage. It could snap the breaker bar so be careful. I myself as well as many other people have ran into the same issue. From the factory, that bolt has Loctite red on the threads. Red = 💪🏻
  #4945
Old 06-19-2024, 07:29 AM
Philip_A's Avatar
I added a cheater bar but that is only 1/2" drive and was beginning to make some unhappy noises.
Instead I may try the starter motor trick. Tie the engine down, get a bigger 3/4" drive bar and see if that shifts it.
Wonder why they specced it that tight.
  #4946
Old 06-19-2024, 11:59 AM
Ken Cantor's Avatar
Received 2,537 Likes on 831 Posts
Plan B beckons
That wouldn't be a '66 Ford Fairlane you keep showing glimpses of in your pictures would it?
  #4947
Old 06-19-2024, 12:32 PM
Quadcammer's Avatar
if you have a big cordless impact, it should get that off no problem. I used my 3/8" dewalt, which is a monster for its size and it came off. Some say that impacts are not the best choice due to vibrations, but I never noticed any issues.
Philip_A (06-19-2024)
  #4948
Old 06-19-2024, 12:37 PM
Philip_A's Avatar
Ken,
1966 yes, Ford no. It's a Plymouth Fury. Currently on the back burner needing a bunch of welding.
​​​​​Phil
  #4949
Old 06-19-2024, 12:38 PM
Philip_A's Avatar
Yeah, that's coming in at Plan Position B, I think. I've got a 3/4" drive windy gun that's more at home taking truck lug nuts off. I think I'll have to dig it out.
I ran out of time and weather yesterday.
Phil
  #4950
Old 06-19-2024, 07:35 PM
nilanium's Avatar
Swapped front brake pad compounds over the weekend just for testing, and on the drive home from work, decided to try a few spirited stops now that the pads had bedded in a little bit... And the front end LIFTED up while heavy on the brakes, and slammed back down as soon as brakes were released.
Guess it's time for new Vee mounts. Both the fronts separated... Sucks cause the ones on there are only a few years old, and fairly low mileage, but I guess that's the cost of running aftermarket. So, shelled out hundreds of bucks for a pair of OEM ones, hopefully they hold up better to spirited driving/braking, otherwise some more involved/custom solution may be needed.
Addicted2boost (06-20-2024)
  #4951
Old 06-20-2024, 05:35 AM
Vauxi's Avatar
At tuesday got her out of hibernation. Went straight to the MOT inspection and it passed with flying colours. Yesterday I did basic yearly service and today new spark plugs. Runs like a jag supposed to run.
  #4952
Old 06-20-2024, 06:46 AM
Hooli's Avatar
I bought my XJR a present yesterday & it's arrived already. A Foxwell NT680pro, which hopefully I won't need much. Been saying I've needed a decent scanner for a while that does more than basic engine codes, saw these on offer from Gendan at £295 rather than £399 so it seemed rude not too. https://www.gendan.co.uk/product_FXNT680PCL.html if anyone is interested.
  #4953
Old 06-20-2024, 07:35 AM
Philip_A's Avatar
I ordered one of those for my old man. Despite everything having been paid customs seized the entire contents of the container it arrived in at the docks and needless to say it never arrived.
  #4954
Old 06-20-2024, 08:03 AM
RandyS's Avatar
Default Customs
I have always wondered what happens to the articles seized in a whole container
when only part of the container violates the customs laws. I would be willing to bet
it happens a lot more than one might think.
  #4955
Old 06-20-2024, 08:25 AM
Philip_A's Avatar
Most likely eventually gets sent to auction.
I found my impact wrench.
We'll see if that frees up the crank bolt.
  #4956
Old 06-20-2024, 10:19 AM
Hooli's Avatar
How damned annoying, I bet you don't get repaid for it after that happens either.
  #4957
Old 06-20-2024, 06:28 PM
Philip_A's Avatar
Hah!
Plan C worked.
Phil
  #4958
Old 06-20-2024, 06:43 PM
Your not done yet until that pulley is off and nothing else is broken. 😄
  #4959
Old 06-20-2024, 06:47 PM
Philip_A's Avatar
One step at a time!
  #4960
Old 06-21-2024, 09:51 PM
Philip_A's Avatar
Only the tool broke, today.
Bigger tool time. Going shopping tomorrow.
Quick Reply: What did you do to your X308 Today?
