What did you do to your X308 Today?
#4961
#4962
Replaced front brake pad I got dynamic friction ceramic 3000 series . Just avoid centric semi metallic their ceramic good but the metallic makes noise while braking but honestly after 1 year of using not too bad but just get ceramic to have peace of mind brembo also makes brakes for our cars
#4964
#4965
#4968
#4969
#4971
Had a set of Bilstein shocks put on the rear along with some new Michelin Pilot Super Sport tires all around. I can't believe the difference in ride quality. Amazingly smooth and quiet. Next week I will do the front struts too. Can't wait! The old tires were 15 years old and the shocks and struts are the originals from when I bought it new. The bushings were corroding from age.
#4972
Removed the driver side (US) O2 sensor.
The OBD light (1647) came on and kept doing so after resets. I got it out from the top after about a half day of removing ancillary stuff. that literally blocks it from view. I cut the four sensor wires and slipped a 7/8" closed end/box wrench over the barrel. A long tube O2 socket (with the slit in the side) would not work because there is not enough space to get a 3/8" socket handle on the end let alone move the handle (at least not from the top). There was just enough space for the box wrench handle to crack the sensor loose. Looks like I'll have to tighten the new one with an open end 7/8 as the plug will not fit over the large plastic electrical plug....maybe I'll try the long O2 socket from under the car...
Since the OBD says a Denso O2 sensor apparently failed at just 40,000 miles, I ordered a Bosch replacement...about $210 with tax and delivery from Rock Auto. Hope this works as I never want to do this job again. I'll be replacing the antifreeze as part of this effort.
#4973
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
#4974
#4975
VDP J2 has been having a few problems recently:
1. The front was making bumping, banging noises when hitting bumps etc. Replaced front shocks and bumpers. Really drives quiet now! No rattles or rude clunking. I had replaced the rears a few months ago along with all the rubber bushings, shock bumpers, etc. Rear end fluid change, U-joint greased so is driving quiet.
2. The RPMs would fluctuate up and down when idling and the trims were a bit out of spec though no codes popping up. Figured there was a bit of a vacuum leak so I removed the throttle body and replaced the power brake line and that little plastic insert under the throttle body mount. The car idles smoothly now and none of the weird surging while driving either. ( I had broken the end off the line where it connects under the throttle body a while back. Had it shoved in and plugged up with RTV but since I ordered and new fitting and had a new booster line, made the swap. The plastic line was loose and the fitting partly broken.)
3. Replaced a tail light bulb on the driver's side. No more messaging!
4. Rotated the tires but it looks like i need two new Michelins on the rear.
It is very hot here in ole Atlanta; 94 degrees showing on the digital thermometer in the garage! Fans going and some chilled beverages to get me through! Enough of that heat. Time to cool off!
#4976
The following 3 users liked this post by HerbB:
#4977
Philip_A (07-09-2024)
#4980
