What did you do to your X308 Today?
#601
Unleashed the Beast within...
At work, printing $75K in checks when the printer throws an error code. Toner cartridge is dead. Thought I had another. Nope. Nearest store is 100 miles away 1-way. It's 2:48P and board meeting (thus approval of bills) is at 6:00P. Off I flew.
Back by 5:18. New cartridge inserted, printer fires, checks printed, then I generate a few expenditure reports. Finished by 5:58P. Nobody knew the difference.
The Jag saved me, plain-and-simple. First time I've run a near constant 100mph for an hour then repeated same. Easy Peasy.
#602
NEW FLOOR MATS. The proper color, fabrick, embroidered "Jaguar", non-slip knobs and correct grommetted holes for the front two. The rear look just as luxurious!
Bought them on Ebay...
http://www.ebay.com/itm/231148183001...84.m1439.l2649
Photobucket link to ALL including new mats
http://s172.photobucket.com/user/rag...?sort=3&page=1
BTW, It's up for sale now... Job fell through...
http://norfolk.craigslist.org/cto/4419634222.html
King Charles (04-09-2014)
#603
#606
Are all your UJ's in good nick?
You lower pendulim inner bushes OK?
Outer lower hub carrier bearings in good condition?
Main front 'A' frame bushes OK?
#607
#608
#609
I wouldn't pay the dealer that kind of money for the coil, it would be worth getting one off ebay for much less. This is my opinion -- if you spend $30 on a coil (as long as it's the right part!) and it doesn't work, all you did was spend $30! Before you do that, you could also check Welsh and some other suppliers to see if you could get an OEM part for less than the dealer charges.
Good luck.
BTW did the dealer charge you for the diagnosis? The dealer here charges $189 just to drop the car off! Also, I see you're in Wisconsin, what dealer did you go to? I have a place in Madison and have been to the Jaguar dealer on the beltline - they seem to be a typical dealership - $120/hr bench rate, high estimates for time and parts.
Good luck.
To be fair, they have always found the problem and fixed it properly; sometimes below the estimate, and they will wiggle if asked. They also have a savings program to save a bit. They have been professional and competent.
The service manager, Mick, has a delightful English accent.
OldMike (04-10-2014)
#610
#611
#613
Some Success
After installing the SCM i tried like the dickens to program my lone remote. Thanks again for the advice on valet mode. I can get the red light to flash and the original beeps but it will not program. Tested remote but just at a local auto parts store. It's a challenge working out the kinks but i'm learning a lot. Last attempt i made sure the car battery was fully charged and had performed the hard reboot by touching the Neg and Pos leads together. I know it sounds stupid but the left side passenger door light is not working. Could this be related?
#614
I listed mine on Craigslist..... Tough times
Craigslist Listing - http://norfolk.craigslist.org/cto/4402455972.html
PhotoBucket with more, Higher quality pics, and info for each pic. - http://s172.photobucket.com/user/rag...?sort=3&page=1
#615
Porsche407 (04-12-2014)
#617
FirstJag7979
Check fuse number 7 in the lower part of rear seat in left hand fusebox (15 amp fuse).
Body processor module (battery supply for solenoids, lamps and motors).
The remote fob was not working when that fuse failed on our 2001 XJ8.
also check the passenger door courtesy light bulb to see if it needs replacement.
Jim Lombardi
Jim Lombardi
The following 2 users liked this post by jimlombardi:
FirstJag7979 (04-14-2014),
Z07Brandon (04-09-2020)
#618
remote problem
#619
I had the car washed, I then applied some polish then I cleaned the aerial. I also glued the 3rd brake light back on after I discovered it had fell off whilst I closed the rear sun blinds. That is the rattle I've had the last few weeks.
I'm looking at my beautiful car right now, sparkling in the evening sun.
King Charles (04-13-2014)
