What did you do to your X308 Today?
Old 04-08-2014, 11:25 PM
Catenaccio's Avatar
Unleashed the Beast within...
At work, printing $75K in checks when the printer throws an error code. Toner cartridge is dead. Thought I had another. Nope. Nearest store is 100 miles away 1-way. It's 2:48P and board meeting (thus approval of bills) is at 6:00P. Off I flew.
Back by 5:18. New cartridge inserted, printer fires, checks printed, then I generate a few expenditure reports. Finished by 5:58P. Nobody knew the difference.
The Jag saved me, plain-and-simple. First time I've run a near constant 100mph for an hour then repeated same. Easy Peasy.
  #602
Old 04-09-2014, 01:28 PM
ragman1171's Avatar
NEW FLOOR MATS. The proper color, fabrick, embroidered "Jaguar", non-slip knobs and correct grommetted holes for the front two. The rear look just as luxurious!
Bought them on Ebay...
http://www.ebay.com/itm/231148183001...84.m1439.l2649
Photobucket link to ALL including new mats
http://s172.photobucket.com/user/rag...?sort=3&page=1
BTW, It's up for sale now... Job fell through...
http://norfolk.craigslist.org/cto/4419634222.html
King Charles (04-09-2014)
  #603
Old 04-09-2014, 02:08 PM
Probesport's Avatar
Pics, link to buy, etc
  #604
Old 04-09-2014, 04:30 PM
King Charles's Avatar
Received 1,023 Likes on 741 Posts
Link, been looking for the same.
  #605
Old 04-09-2014, 08:27 PM
Zorasmiles's Avatar
Triple request for the link. I have a set but the proper color would make me smile.
  #606
Old 04-10-2014, 06:05 AM
xjay8's Avatar
Originally Posted by richard thomas
I went for a cruise after replacing this:
with this:
Took a couple of days to clean up and fit replacement diff (which was the reason I had to drop it out) etc, but well worth it!
Good job!....did you have any problems with your 'trapese' bushes?
Are all your UJ's in good nick?
You lower pendulim inner bushes OK?
Outer lower hub carrier bearings in good condition?
Main front 'A' frame bushes OK?
  #607
Old 04-10-2014, 06:48 AM
Porsche407's Avatar
Me four!
  #608
Old 04-10-2014, 06:52 AM
Porsche407's Avatar
Sounds great... Did you buy a spare or are you looking forward to the next "crisis" to do it again!?!
  #609
Old 04-10-2014, 07:28 AM
JaguaXJR's Avatar
Originally Posted by OldMike
I wouldn't pay the dealer that kind of money for the coil, it would be worth getting one off ebay for much less. This is my opinion -- if you spend $30 on a coil (as long as it's the right part!) and it doesn't work, all you did was spend $30! Before you do that, you could also check Welsh and some other suppliers to see if you could get an OEM part for less than the dealer charges.
Good luck.
BTW did the dealer charge you for the diagnosis? The dealer here charges $189 just to drop the car off! Also, I see you're in Wisconsin, what dealer did you go to? I have a place in Madison and have been to the Jaguar dealer on the beltline - they seem to be a typical dealership - $120/hr bench rate, high estimates for time and parts.
Fields, on the south beltline.
To be fair, they have always found the problem and fixed it properly; sometimes below the estimate, and they will wiggle if asked. They also have a savings program to save a bit. They have been professional and competent.
The service manager, Mick, has a delightful English accent.
OldMike (04-10-2014)
  #610
Old 04-10-2014, 03:46 PM
andrew lowe's Avatar
Refitted the front wheels after having new Pirelli P Zero 99Y s to match the ones fitted to the rear at the end of October. I then removed the windscreen wiper, scuttle panel and the three panels over the false bulk head so as to be ready for the new front screen in the morning.
  #611
Old 04-11-2014, 03:39 AM
Sean B's Avatar
Received 1,371 Likes on 1,078 Posts
Put a fresh battery on and fired her up after 6 months in storage, ready for some summer trips after a few little things like an oil change and a cut and buff.
  #612
Old 04-11-2014, 04:11 AM
Going to have it detailed(wax,Rain-X the whole 9) then install the chrome door handle finishers from Mina Gallery as spring has finally sprung ie 81 FH today in coastal N.C.
  #613
Old 04-11-2014, 01:25 PM
FirstJag7979's Avatar
Default Some Success
After installing the SCM i tried like the dickens to program my lone remote. Thanks again for the advice on valet mode. I can get the red light to flash and the original beeps but it will not program. Tested remote but just at a local auto parts store. It's a challenge working out the kinks but i'm learning a lot. Last attempt i made sure the car battery was fully charged and had performed the hard reboot by touching the Neg and Pos leads together. I know it sounds stupid but the left side passenger door light is not working. Could this be related?
  #614
Old 04-11-2014, 03:48 PM
ragman1171's Avatar
I listed mine on Craigslist..... Tough times
Craigslist Listing - http://norfolk.craigslist.org/cto/4402455972.html
PhotoBucket with more, Higher quality pics, and info for each pic. - http://s172.photobucket.com/user/rag...?sort=3&page=1
  #615
Old 04-11-2014, 07:53 PM
Post the link where to get the floor mats.
Porsche407 (04-12-2014)
  #616
Old 04-11-2014, 08:32 PM
ericjansen's Avatar
Received 1,354 Likes on 928 Posts
Default Dash rings
Got the interior a bit more detailed.
Bought the rings in the UK.
Extremely pleased with the result for the larger gauges and the clock, but the jury is still out on the switches.
Next up: cleaning the leathers.
Attached Thumbnails What did you do to your X308 Today?-dsc01403_zpsb1cf20c2.jpg   What did you do to your X308 Today?-dsc01407_zps9ba6b3a7.jpg   What did you do to your X308 Today?-dsc01406_zps93ecc0d8.jpg
  #617
Old 04-11-2014, 08:54 PM
jimlombardi's Avatar
Received 1,624 Likes on 874 Posts
FirstJag7979
Check fuse number 7 in the lower part of rear seat in left hand fusebox (15 amp fuse).
Body processor module (battery supply for solenoids, lamps and motors).
The remote fob was not working when that fuse failed on our 2001 XJ8.
also check the passenger door courtesy light bulb to see if it needs replacement.
Jim Lombardi
Attached Thumbnails What did you do to your X308 Today?-2003jaguarxjdoorcourtesylampbulbremoval_zpsa977c4d2.jpg
The following 2 users liked this post by jimlombardi:
FirstJag7979 (04-14-2014), Z07Brandon (04-09-2020)
  #618
Old 04-12-2014, 01:03 AM
Default remote problem
Checked all the fuses with no luck but will try the bulb next. Thanks for the advice.
  #619
Old 04-12-2014, 12:41 PM
Stu 1986's Avatar
I had the car washed, I then applied some polish then I cleaned the aerial. I also glued the 3rd brake light back on after I discovered it had fell off whilst I closed the rear sun blinds. That is the rattle I've had the last few weeks.
I'm looking at my beautiful car right now, sparkling in the evening sun.
  #620
Old 04-12-2014, 03:12 PM
ragman1171's Avatar
1995 2003 Jaguar Vanden Plas Floor Mats Tan 4 PC Set w Jaguar Monogram | eBay
Good Luck!
King Charles (04-13-2014)
Quick Reply: What did you do to your X308 Today?
