What did you do to your X308 Today?
#801
#803
Just put all the door panels back in after fixing my door latch micro switch problem. All four doors were fried. Had the driver side front bearing replaced and just had my CEL cleared by getting the vent valve replaced. Fixed the sport switch that would not stay locked. Rear brake job this week and she'll be perfect.
#804
[QUOTE=Sean B;617862]How has that happened?
The panel adjustment is at the hinge and bump stops for in/out - up/down movement. Not an easy job to get right, when you move the panel you've got to keep checking all the shut lines.[/QUOTE
![](http://farm9.staticflickr.com/8196/8146403812_72e1fcf0f0.jpg)
For years I've been looking at my trunk lid with the same problem wondering if it had been in an accident with the previous owner. A small adjustment in the rubber stopper and it looks completely normal!
Sean B (08-05-2014)
#806
#807
#808
Spend the last 3 days working through a long list of mainly small issues inside and out.
Mostly non-issues, just because I am a sucker for perfection.
Finished it off with a polish.
Took her out after all that, parked her up, set my camping chair, and enjoyed the beautiful lines while sipping my coffee....I can look at her design for hours.
![Name: DSC02169_zpsa0dcc5b6.jpg
Size: 155.6 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/157633d1501259770-what-did-you-do-your-x308-today-dsc02169_zpsa0dcc5b6.jpg)
#811
Looks great!
Love the licence plate hanging straight off the bumper, instead of having a plastic frame behind it. I've done the same and it cleans up the front soooo much.
One day I'll get a 'euro' style plate, which is wider and shorter, so it obstructs less of the opening underneath the bumper
#813
Over the last two days I took a clay bar to the whole car. Waxed from top to bottom, front to back. Took each wheel off cleaned, polished the wheels. Leather cleaner and conditioner inside. Cleaned carpets and floor mats. Cleaned windows inside and out. Rewaxed the top section hood, roof and trunk since it gets the most sun.
Installed new Cat on hood, changed air filter with oil change to follow in the coming days.
Larney
Larney
#815
Larney
Larney
That is the excact treatment I give my car once a year and it still looks gorgeous.
I always wash with the two bucket method.
How about a coup[le of pics of the finished article? ;o]
#816
Keeping these beasts in alignment goes a long way to cutting down drag.
I reckon the 'sweet spot' is around 75mph as the motor is in the torque band which means you can relax the throttle...I hate using cruise control
as it actually has the effect of increasing fuel consumption and using cruise below 50 mph is patently rediculous.
#818
#819
![Talking](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
Installed a Kenwood KDC-X998 receiver with Infinity speakers. Sweet sounds, 2 USB ports, Bluetooth for the phone and music streaming and probably a hundred things I'll never use....chuckle. I couldn't be happier with the setup!
Quick note: the wiring diagrams for the speakers is different that what's in the car...it's all easy enough to figure out as Jag, in thier infinite wisdom, saw fit to twist the speaker pairs together.
#820
