What did you do to your X308 Today?
Old 06-18-2015, 06:50 PM
Jhartz's Avatar
yeah, they made it look like a panther instead of a jaguar. Still, pretty cool.
  #1042
Old 06-19-2015, 08:16 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
#bigheadon#
Technically, a panther is a jaguar... It is just a melanistic colour variant of a jaguar in the Americas It is actually a very rare melanistic condition for jaguars (more common on leopards).
#bigheadoff#
thelegend0210 (10-12-2023)
  #1043
Old 06-19-2015, 09:34 AM
Could you imagine it... Panther cars.... an XF Panther or a Panther X-Type.. all available in any colour as long as it is black :-)
  #1044
Old 06-19-2015, 10:07 AM
80sRule's Avatar
Originally Posted by Daim
#bigheadon#
#bigheadoff#
It's really cool seeing a melanistic spotted cat up close; the car equivalent is like ghost flames and such. Yes they're black, but you can still kind of see their spots up close.
  #1045
Old 06-19-2015, 11:26 AM
andrew lowe's Avatar
Unless it is behind armoured glass or similar, I don't want to get that close to see if its got spots or not!
  #1046
Old 06-19-2015, 02:11 PM
badger2196's Avatar
Okay, my leaper is finished and looks exactly how I imagined it would And the word I was trying to "make" was: WEAR. Every Jag wears in... And this is a artificial wear on a black metallic leaper
Just got to drill the holes in the bonnet to fit it Oh, and the rest of the chrome will be treated the same way
Each to his own I guess, but please, for all our sakes, remove that "V8 Inside" sticker.
  #1047
Old 06-20-2015, 01:50 AM
Daim's Avatar
Nnnnnnnnnnnope! Tis still my car I get the odd smiles when people see it so I'm happy
People don't know that these cars come with V8s. They think V6s are the biggest engines at most.
  #1048
Old 06-20-2015, 02:58 AM
Pilotman11's Avatar
Looks great Daim! I wonder how the rest of your Jag will look when your done!
  #1049
Old 06-20-2015, 12:11 PM
Daim's Avatar
VERY different... I'm going a really "anti-Jag" way...
-> flat/matte black
-> lower
-> no chrome
-> X300 grill and light surrounds
-> XJ6R rims
So it will be very very different
  #1050
Old 06-20-2015, 03:14 PM
Pilotman11's Avatar
Cool! Can't wait to see how it turns out! When do you expect to have it done? Good luck
- Pilotman
  #1051
Old 06-20-2015, 05:08 PM
If you are going for a matte black finish, may I suggest that you either go for some sort wrap or maybe plasti dip.
A friend of mine has a factory matte black finish on his motorcycle, it does look really cool ( like something batman would ride ) but it drives him nearly insane trying to keep it clean!
Even a simple thing like bird poop, if not removed correctly, can severely marr the finish.
You cannot use ordinary shampoos or cleaners, and obviously you dare not go anywhere near it with polish.
  #1052
Old 06-21-2015, 07:54 AM
bdboyle's Avatar
"A panther's like a leopard,
'cept it's not been peppered.
Should you behold a panther crouch,
Be prepared to say "Ouch".
Better yet, if called by a panther,
Don't anther."
-Ogden Nash
Patioboater (06-30-2015)
  #1053
Old 06-21-2015, 12:32 PM
Daim's Avatar
- Pilotman
It'll be a while yet. Need to get the car running properly first. Then lower... Then black.
I'll be painting with paint... But not normal car paint. Instead an acrylic paint which should also stop the rot chances...
  #1054
Old 06-21-2015, 07:38 PM
CharlzO's Avatar
Adjusted the throttle cable (WOW there was some slack there), and replaced the weatherstripping on the corner panels under the hood while I was there. Next weekend, I'll probably Simple Green the whole engine and try to get some clean under there! I did wash the car today - drove it to dinner and came out to rain. Always how it works, but..eh.
  #1055
Old 06-29-2015, 02:33 PM
ZeroedIn's Avatar
Thumbs up A little TLC
Picked up the kitty first thing this morning, from our local indie Jag shop. I had the following done while I was traveling for business last week:
1) Idler pulley on serpentine tensioner - replaced
2) Serpentine belt - replaced
3) Rear shock mount, and spring seat bushings - replaced.
Back to a cat-like, stealthy quiet ride.
Next maintenance to be done is a standard oil change and lube.
P.S.: Almost forgot - two weeks ago, I replaced the auto-dimming mirror with a replacement I found on Amazon. Had to, because the liquid electrochromic fluid in the mirror went off, and it developed the bubble. There is a great thread in these forums that covers this topic!
Cheers.
Last edited by ZeroedIn; 06-29-2015 at 02:36 PM. Reason: Almost forgot about the electrochromic mirror replacement
  #1056
Old 07-19-2015, 05:45 AM
Daim's Avatar
Installed my black leaper today
The following 2 users liked this post by Daim:
bdboyle (07-19-2015), Patioboater (07-22-2015)
  #1057
Old 07-19-2015, 07:57 AM
bdboyle's Avatar
daim: That looks just righteous.
Daim (07-19-2015)
  #1058
Old 07-19-2015, 10:29 AM
Daim's Avatar
Cheers mate. Grill is next. And some other parts
bdboyle (07-20-2015)
  #1059
Old 07-19-2015, 02:12 PM
beady's Avatar
Finished replacing my AC compressor and dryer on 2002 XJR.
Once I had the belts off I found my supercharger idler bearing was feeling rough so I replaced it. Also broke one of the small coolant lines as it was brittle, so had to replace that.
Hopefully pull a vacuum and charge AC tomorrow.
  #1060
Old 07-21-2015, 12:16 AM
VR6Guru's Avatar
Had an oil change, and the two front motor mounts changed
Quick Reply: What did you do to your X308 Today?
