What did you do to your X308 Today?
The following 2 users liked this post by ericjansen:
rocklandjag (02-01-2016),
xjay8 (01-31-2016)
#1322
As it happens, I was doing about 20-25 mph with my foot on the brake slowing down to turn into the road I live on, when.....BANG!.... WTF!....pull into the kerb, gently, and I mean gently as in holding her on the footbrake and letting her roll on idle, a few feet BANG, a few more feet BANG.
Luckily I was only a few hundred yards away from home, so at less than walking pace, and making some horrific noises, I limped the old girl home and chucked her in the garage.
#1323
Dobyou have some instructions wich wires to connect, as I would like to do this too
#1324
I had a separate thread on this matter, as I ran into some wire abracadabra, solved with the help of bdboyle.
I ran an update just now (post 6) with some guidance.
https://www.jaguarforums.com/forum/x...8/#post1391038
Feel free to ask for particulars if needed, but I think it is a rather straight forward procedure.
E.
#1325
Made an appointment for Friday morning, to get my sporadic "Low Coolant " light checked via pressure test & a new battery as old man winter finally settled in here.
Update/Edit :
Got a great deal on an AutoCraft Gold battery Part No. 49H8 w/ 900 CCA was 25$ cheaper than all the other local shops & was installed by one of my area's most reputable shops. My old one tested @ 300 CCA so it was past due.
My cooling system checked out fine, which kind of baffles me. I've had this car 4 mo's now(approx. 1,200 miles) & had the "low coolant" light twice & having to add 6-8 oz. of coolant each time. Both episodes were after extended freeway driving, usually after a brisk passing session(70-80 mph).
Update/Edit :
#1326
Did an alignment: steering was well out, rear right track too
Set my headlights: left was just above the perfect setup but wouldn't go down any further. Moved the bulb, all fine now.
Rotated tires: irregular tyre wear one the front due to bad tracking.
Check water leaks: all sealed.
Set exhaust up: doesn't point everyhwere noe.
Found rust: loads of it at the front sill tips.
#1327
I thought about dropping the back axle out to change my blown diff.... Then I looked out the window, its grey and damp and not very warm.
After all, I have to walk at least 45 yrds to the workshop!
So it was either spend Sunday rolling around on a cold concrete floor under a Jag, or sit in the warm and chill out.... guess which option won?
Yep, feet up, cup of tea, telly on, the aroma of SWMBO in the kitchen cooking the roast wafting past my nose.....
#1328
#1330
Took it out for a bit of exercise yesterday, including a spin on some winding roads and an evening highway drive across Detroit with my wife for an event.
I try to keep it off the Michigan roads in the winter because of all the salt, the potholes, and the general flying debris from our disintegrating roads. But I also don't like to let it sit too long, since that's hard on the battery. Every now and then we get a decent winter day when I can take it for a spin and make sure the battery is still charged. Yesterday was one of those days, and it was great fun.
#1332
Rotated tires: irregular Tyre wear one the front due to bad tracking.
Set exhaust up: doesn't point everywhere now.
Usually caused by silt and muck being caught behind the rear end of the inner guard liner at it's bottom edge.
If you peel this back you can give it a good wash out and inspect for rust damage.
#1333
Patioboater (02-01-2016)
#1335
Fixed my rear driver's side door, the handle had stopped working on the inside. So I pulled the door card off, and the catch at the latch inside had come off the notch. So once that was on, I also replaced the stock air box back in place of the K&N cone and shield I had put in. I'm planning a road trip in a couple months so I figured I'd get the car acclimated to the stock filter again and save myself a mpg on the trip. And, it gives me time to make a better shield template when Spring gets here. All in all, a productive day. Well, at least it will be for anyone who rides in the back.
#1336
Today was a nice clear day; perfect day for a wax. Halfway into my wax job I look up at the sky and see some dark clouds in the distance; I thought it wouldn't be a big problem. I go inside to grab my keys and once I'm outside it started to hail; and lots of it came down. So now the Jag has half of a wax job until my day off Tuesday.
So much for 10% chance of rain.
#1337
Wanted to change the right front wheel bearing. No problem until removing the ABS ring. Heat, WD40, impact wrench, breaker bar - no success. Ended up in putting all back together and cleaning the relevant parts. Next friday, I'll try again with breaking the old ring with a chisel and replacing with new (which I ordered immediately). Since they're cheap to get I blame myself not having ordered it right from the start.
At least I replaced the blue bulb of the "Sport" button and fixed the broken brackets of the radio and climate control units. However, two more bulbs blew when putting all back together (front seat heating and "Valet" button)
Will go for it next time when polishing and waxing the wooden veneer.
#1338
Yep. So I'll get that area welded and then improved by making a plastic cover to extend from the arch trim. Also, two other spots, underneath the rear heatshields in front of the rear axle. They are not crispy yet on my 1998 but they have some surface rust. Time to react!
#1339
