What did you do to your X308 Today?
Old 05-08-2016, 04:21 PM
Originally Posted by vsol
damn i want to do this... do you have any video clips demonstrating?
where'd you mount the toggle switch
No video because is really wouldn't show the full capability of the system. It is so variable what would I show you? Just imagine going from stock, luxury car quiet to full out race car with straight pipes in about 3 seconds, you can also open them any amount in between for a little growl or a more aggressive sound.
I mounted momentary contact toggle the switch where the ashtray used to be in the center console.
Vector
  #1542
Old 05-08-2016, 11:24 PM
Pilotman11's Avatar
Detailed after continuous rain within the past few days; she looks great all clean!
  #1543
Old 05-09-2016, 10:39 AM
harvest14's Avatar
Beautiful paint Pilotman11!
Today I SUCCESSFULLY got the JTIS software working on my laptop! I tried last Summer and got really frustrated; gave up. I figured "hey, if you are capable of replacing all of the timing gear on a Jaguar, surely you can get a silly piece of software to work". So, I tried again this morning...
Victory. Hopefully this will mean I ask a lot fewer questions for the veteran members to deal with.
  #1544
Old 05-09-2016, 01:18 PM
80sRule's Avatar
I work as a Software Engineer and my specialty is legacy systems and legacy porting and it took longer to get it going than I'd like to admit lol.
I have to say that I like the Jaguar JTIS procedures than the garbage I've printed out from my Bentley manual for my Audi A8. Best still goes to Suzuki for my GSXR1100 manual; easily the best written and illustrated FSM I've ever used. It doesn't hurt that I can do almost everything on that thing with simple hand tools.
  #1545
Old 05-09-2016, 08:53 PM
plums's Avatar
Received 2,183 Likes on 1,623 Posts
If you've looked under the hood of JTIS and IDS,
you'll realise that it is some of the worst design
and implementations ever conceived by amateurs.
  #1546
Old 05-09-2016, 09:44 PM
dsetter's Avatar
Pulled SC and inlets and associated paraphernalia on the way to pulling the heads to hopefully only do head gasket, and slight refresh if possible, else it's a parts car.
  #1547
Old 05-09-2016, 10:06 PM
80sRule's Avatar
I'm okay with mystery! I learned at work that the more old code I work with, especially written by contractors without code review, the more I'm ok with keeping the decrepit man behind the curtain actually behind the curtain.
  #1548
Old 05-09-2016, 10:26 PM
plums's Avatar
As long as it's paid work at consultant rates on a
time and materials basis, then yes.
But when it's stuff you use for unpaid work .... grrr!
And the new stuff churned out by "software engineers"
using "integrated development environments" ... OMFG.
/rant
Back to regularly scheduled programming now
  #1549
Old 05-09-2016, 11:32 PM
Forcedair1's Avatar
Well, after a few more incidents of ASC track unavailable and its inevitable (and major PITA) limp-home mode and after cleaning, inspecting and testing the wheel speed sensors without much success, I've finally taken her back to Nigel, here at British Eurotech, after about three years since he worked on this same problem last.
Positive responses from various members who claim not having had such bad experiences with this issue kind of give me hope to stay and not to divorce her after all... I want this car, what can I say? I sure hope that Nigel can kill those gremlins so I can continue progress with a few upgrades.
If things work out, the tired, but not damaged, paint will get either a nice buffing, or better yet, get wet-sanded in a similar fashion as my XJS show car was achieved (although that was on new paint). Man, that Zircon paint would probably look absolutely phenomenal. Also getting the sagging headliner taken care of and just maybe new leather on the front seats, probably not cheap. BTW, how much should I pay for the new leather seats?
Cheers,
  #1550
Old 05-10-2016, 11:53 PM
DimitrisBXL's Avatar
Installed a new window switch box on my door. I am so happy i can open my window again and operate the two rears too. :-D
  #1551
Old 05-21-2016, 03:51 PM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
Tanked some gas and found out, that my old XJ can still shift from the lights if floored.
And I also changed the front pads and discs. Easy job. The discs simply came off with no hassle... Love it when things go well
  #1552
Old 05-21-2016, 04:40 PM
weatherforcast's Avatar
removed my 5hp 24 transmission.........PITA
Johnny_B (06-03-2016)
  #1553
Old 05-21-2016, 07:14 PM
k-man's Avatar
Pulled the fue..... errr petrol tank and replaced both fuel pumps with a pair of HFP-382's from Amazon. Half the price of the Delphi units and seemed to be of the same quality, no noise whatsoever.
Also those lower fuel lines are a MOTHA#&$%#@!
  #1554
Old 05-22-2016, 08:21 AM
EastCoastYost's Avatar
New headlight and new valve on the evap system. Hopefully no more mass evap leak.
Trans fill looks like it may be next.
  #1555
Old 05-22-2016, 11:28 AM
Replaced the rear brake light bulb. :-)
  #1556
Old 06-02-2016, 10:28 PM
nilanium's Avatar
Finally got the tools and opportunity to do primary and secondary chains, tensioners, related gaskets, etc. Pulled the front cover (after spending an hour fighting a rounded bolt head).
Discovered the cause of the rattle was not just worn tensioners, but that there was about 4 inches of one of the primary guides completely gone. Bolts on the corresponding primary tensioner were not even finger-tight, and i believe one of the bolts snapped off inside the block...
bolt snapped in the block?
Something is missing here..
Buttoned it all back up loosely, now to wait for a day without rain or work to play operation with that broken bolt.
  #1557
Old 06-03-2016, 06:14 AM
xjay8's Avatar
Begs me to ask....how long have you had the car and how many mile son it?
Has this car had worked performed previously?
  #1558
Old 06-03-2016, 11:15 AM
nilanium's Avatar
98k mi. Got the car as a mechanic's special a few weeks ago, the previous owner garaged it a few years back when it started to rattle. He started it once to show it ran and drove (which is kind of surprising with this damage), and I started it once for about 30 secs to test the alt and verify noise was coming from tensioners.
As for work done previously, I'd assume not with the tensioners. Previous owner mentioned the whole top end of the motor was rebuilt, but I'm pretty doubtful of that. The SC, V8 plate, and intercoolers are all showroom clean, with what looks like a fairly poor repaint with factory or close to factory color.
xjay8 (06-05-2016)
  #1559
Old 06-03-2016, 02:00 PM
Samilcar's Avatar
Looks like when the guide broke loose on one side, it smacked the chain on the other side with enough force to shear that tensioner bolt.
nilanium (06-03-2016)
  #1560
Old 06-03-2016, 09:02 PM
nilanium's Avatar
Sounds like a reasonable explanation. In that case I'll replace both bolts for that tensioner, and maybe the other primary, since I think my kit only came with bolts for the secondaries. Is there a special bolt needed, or just any bolt with the correct thread and length?
Quick Reply: What did you do to your X308 Today?
