What fuel injectors in a 98 X308 (XJR)?
Can someone tell me the part number or manufacturer, or both, for the fuel injectors in a supercharged 1998 X308? What's a reasonable price per unit for replacement? How easy are they to change? Any additional information?
They were great until I recently had new plugs installed, and now I get a rough idle and restricted performance alert on start-up. The mechanic said it looked like I'd have to replace one injector, and he said he'd put some injector cleaner in the tank. Is it normal for this to happen after plug replacement? After the car comes up to temp, the idle smooths out to normal...
Fuel injector replacement instructions XJ8 99 VDP
Hello Everyone,
does anyone have any detailed instruction on how to change a fuel injector? I have cylinder #7 misfiring and coil and spark plug replaced and cleaned, power to coil using NOID Light for testing, MAF cleaned, same cylinder misfired after cleaning with fuel cleaner last year and then cleared up. I bought a new Jaguar OEM injector. Having problems removing fuel rail off of all injectors with retaining clips removed so I can replace number 7.
<<<Mathew>>>
<<<Mathew>>>
Mathew - It seems you have "adopted" another thread with an entirely different issue. This thread was a misfire on an XJR.
The fuel rail should wiggle off of the injactors on a NA X-308, after the clips and bolts are loose. There are some o-rings in there that are a tight fit and they can get sorta stuck.
Good Luck
Good Luck
Charlene n John
09-28-2015 06:01 AM
