what gasket set and head bolts?
I'm (finally) getting started on putting my Jag back together. I found a pair of used heads on ebay to replace my warped ones, but I'm going to need gaskets and head bolts. Any recommendation on a brand to use, or even a warning on ones NOT to use.
I'm going to need head gaskets (obviously) and intake and exhaust manifold gaskgets, what else? I've got the supercharger and the entire intake track removed, is it safe to reuse most of these gaskets?
If I remember the factory service manual says to replace just about every gasket, I'm sure it would be ok to reuse a few of them, but which ones?
Also need some head bolts, what do you recommend?
I would not use the head bolts more than once. And the price of the genuine ones has come down from GBP 8+ to now 3+.
With regard to MLS gaskets, they require the block deck and the head faces to be almost perfectly flat and re-faced to very fine grain; otherwise they will leak, maybe not much but enough to cause slow coolant loss. Refacing the heads is easy but block decking requires complete engine strip-down and, if this is not done (and the block deck is no more than 0.1 mm out of flat) better to go with the standard OE composite gaskets.
Its a used car and I don't have a complete history of the car. Taking the bolts out it didn't seem like they had been removed before, but you never know for sure, for peace of mind i'm going to just assume they've already been used 3 times and just replace them.
As far as I know, Jaguar initially specified only one use of the bolts. At some later point, they made a "concession" allowing just one more (second) use.
The part numbers I have are AJ88987 for the RH bank and AJ88988 for the LH bank.
You need the Jaguar replacement. The Lincoln LS head gaskets are different.
I got mine from RM European for around $50 each.
I was hoping to just buy a whole gasket set and not have individually order each one separately.
hows the quality of those aftermarket?
I had the same question in mind - and I bought genuine; didn't want to take any risks on a supercharged engine. If for a 3.2 N/A, perhaps I would go with aftermarket. On the other hand, the fact that Barrat are selling the aftermarket ones provides some assurance of quality.
A couple of points regarding installation:
1. I presume that you will have the heads refaced, just a smallest amount which will make the faces flat and clean.
2. Get a good straight edge and measure the flatness of the block decks; if no more than 0.1 mm, it will be fine with composite gaskets (not with MLS).
3. Make sure that both faces, block and heads, are thoroughly degreased (Zippo lighter fluid works well, not petrol as it leaves some oily residue).
My block faces were about 0.1 mm out of flat (down) in the middle. I used a block of 10 mm thick glass with sandpaper (high quality silicon carbide, not just any) attached to it and, after hours / days of sanding the block faces, more on the sides and avoiding the middle portion, I managed to bring the out of flat to about 0.05 mm.
