What happened?
What happened?
Hello everyone! Yesterday, I got in the Jag and when I entered, the seat moved all of the way to the steering wheel when I put the key into the II position since I have auto mode on; moved every part of the seat forward.
I moved my seat back, then hit 1 to go to my memorized position, and it again, moved all the way forward. All of the memorized seat positions have been reset. Not to mention, the radio, and climate control were off and I had to turn those back on. What happened? I'm still trying to find that "sweet spot" to get my seat as the way I had it before. Thanks everyone!
- Pilotman
- Pilotman
Pilotman11 (08-13-2015)
I uploaded the TSBs for memory seat diagnosis and repair in the large file area. Most people leave the mode switch in the OFF position when one or more feedback pots (position sensors) fail. I rarely repair them anymore. I did dozens in new car warranty but only a few for 'customer-pay'. The sensors are about $300 each and there are 5.
The labor is probably 4 or 5 hours to replace all 5 so for $2000 you can have the seat back to fully functional memory until the wire harness under the seal becomes faulty from the rocking/twisting/chaffing.
If the seat moves manually then you might want to leave the switch OFF but that is your call.
bob gauff
bob gauff
The following 5 users liked this post by motorcarman:
Lear45 (08-13-2015),
Pilotman11 (08-13-2015),
RJ237 (08-13-2015),
smtguy (08-14-2015),
xjay8 (07-14-2017)
Pristine97XK8Convertible
04-28-2017 11:08 AM
