What to look for on a 1999 XJR with 100K? Nikasil problems?
My engine (1999) is the original and has 148K on it. Compression is still excellent. Nikasil is an excellent cylinder wall material. I've got plenty of experience with it via Mercury 260Hp outboards so I wasn't scared.
If you have a good Nic motor, the chances are you will wear out the rest of the car before the cylinders wear out.
