what Module stores the trouble codes
Depends on the code e.g. ABS codes will be in ABS module and so on. The only codes a typical tool can read are in the PCM and the tool can clear them. Of course the fault may still be there and can immediately re-flag so may look like the tool failed. Fix the fault....
The OBD idea is that you always carry out a fix before a clear. Codes self-clear when fault fixed so strictly you don't need to clear the code.
