What is this noise?
That's the first thing that came to mind when I saw the first post. May need a bleed/fill, maybe just needs driven to get bubbles worked out (mine was like this after sitting for a few months, a short drive resolved it), or the pump may be going bad.
JMorris, do you have the shop manual for instructions on how to fill/bleed the SC coolant circuit?
The 2 cabin blower motors even in the off position can still maybe have a light running flow for government regulatory cabin ventalation so no carbon dioxide poisoning
You can pull the fans fuses or relays to tell
there is also a small sample air fan below and to the left of the steering column , this fan can get clogged and cleaned with air only and no solvent
I don’t have any manual - is it an easy enough process?
Most likely the intercooler/supercharger pump.
I replaced mine earlier, have a look at this thread for lots of useful information:
https://www.jaguarforums.com/forum/x...t-pump-199158/
If you want to hear what mine sounds have a look here:
https://www.team-bhp.com/forum/diy-d...ml#post4379946
If you scroll through the various post you will come across all the details of replacing it.
Good luck
Jeroen
Good luck
Jeroen
Elizabeth Blake
09-17-2019 08:12 PM
