What oil to use on a 1999 XJ8
I bought my 1999 XJ8 with 75k miles in February. I took it to a jiffy lube for a oil change This month in June. They put 7 quarts of Mobil synthetic oil 5w30. I am concerned if the oil is too thin for this type of car or even Summer. Does anyone have an answer? I made the oil change last weekend. IF it is the wrong one they gave me i will take my car back for a refund or a oil change again. I am concerned cus yesterday when I turned on the engine it sounded like it had no oil. a bit of grind or flopping sound but the oil is full. :/
The words "upper cam chain tensioners" come to mind here. You need to check where the noise is coming from. As a '99 car, you will have the plastic-bodied upper tensioners, and these fail in a big way, causing the engine to be damaged. Replace them immediately !! (unless you know they have been done, and the noise is coming from elsewhere).
Received 2,266 Likes
Here's what my Jaguar mech recommended for me..just had my first oil change for it since bought. Yes, it was an $80 oil change.
http://www.total-lubricants.ca/en/to...s-quartz-9000/
Total Quartz 9000
Says it's big in Europe with Mercedes and BMW cars
Total Quartz 9000
$73 bucks...where did I go wrong?...I only charge my customers $50 bucks....how can I get in some of this action?......For an extra $23 bucks, I could have taken my wife to McDonalds last saturday night....but wait, I'm not washing them....OK, that makes more sense now...
Because of my own experience, I can't pass the chance to say - Check Out The Tensioners in Your XJ!!!!!!
One of mine broke at 77,000 starting it up in the drive way and I am now in the middle of pulling the heads to repair the valve damage.
I wish I had taken the issue more seriously, believe me.
