What is this part near oil filter?
Iconoclast (03-24-2020)
Received 1,807 Likes
youngowner (04-17-2020)
Looks like the oil pressure switch.......
https://www.sngbarratt.com/English/#...assembly/13802
Carnival Kid is correct. The lower/outer switch is for oil pressure.
The temp sensor is higher up and tucked closer to the crank.
I just looked at a 4.0 AJ27 I have on an engine stand.
Carnival Kid (03-23-2020)
I took that photo after oil drained & was having much difficulty removing my old oil filter. (I posted re which oil filter wrench to buy since mine was not working well)
https://www.ebay.ie/itm/JAGUAR-Genui...sAAOSwAO9ZTCWS
This may not be the source of the leak but may be an easy troubleshoonintg step since I cannot see any oil leaking from above the oil pan dripping down onto the oil pan.
I replace the oil pan gasket 1 year ago with genuine Jaguar part & it only goes in one way & I am sure I positioned it correctly. I switched to Mobil 1 high mileage oil.
After the change I had a reoccurrence of the leak which went away in a month & 6 months later started up again. I can now see fresh oil all along the back of the oil pan. My old oil filter was on VERY tight & my drain bolt was also tight so doubt it is either of those.
After I changed oil & filter (always use a new genuine Jaguar drain plug, never reuse. Always genuine Jag filter.) I saw leak next few days & today it may have stopped but I doubt it. It probably leaks constantly, very little & accumulates & only sometimes drops on my driveway (I place cardboard to catch oil drops). Cannot say whether a long drive makes it leak more vs. less.
This is not my main car anymore. Most days I just move Jag from driveway to street & later back again to driveway (no overnight street parking allowed) Need driveway clear to access my other cars.
I think I posted about my oil pan gasket change I will search.
I found my old post:
“Synthetic Oil Causes Gaskets to Soften, Leading to Oil Leak”
https://www.jaguarforums.com/forum/x...l-leak-202163/
My post # 35 has pic of oil pan. So did not see fresh oil back then!
My post # 38 has details & photos of gasket change & oil pan b4 cleaning
I did not take any pix of the new gasket in place. I wish I did.
ellenm
03-25-2014 02:14 PM
