What is "sonnax"?
Sonnax is a company that makes transmission rebuild kits and other transmission related things.
Transmission - Sonnax
This is to avoid issues with the A-drum breaking due to uncommanded pressure spikes. There is an updated pressure regulator valve that replaces the original and fixes the issue.
A search for "ZF5HP24 A drum failure" should get you more info, as well as this PDF...
http://jagrepair.com/images/AutoRepa...0ZF5HP24-1.pdf
mikebaker3 (01-15-2015)
