what tranny in 03 XJ8--problems??????
i amlooking to buy a beauty and need to know about the tranny ---good or problems !! I beleive th 4.0 engine by 03 has fixed their problems ?? thanks doug 352 634 4685 bkrdoug@yahoo.com
Doug,
I've also heard the 03 engine had the bugs worked out of it. As far as the trans goes it's a ZF 5HP24 and is somewhat controversial. FWIW, mine has 157,000 miles on it and has never been opened. Then again I don't drive like a madman and I know the previous owner was pretty conservative too.
That said the A-Drum in the trans is it's weakness so when I found a trans with only 50 K on it I grabbed it and put it in the garage just in case.
My suggestion is to drive it when it's stone cold. Don't even let the car warm up. If it's holding first gear to long plan on trans work.
There is quite a debate on whether to change the fluid or not. Mine has the original fluid.
D. Fite (12-12-2011)
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
