What type of Fuel do you use?
omgimali (11-07-2016)
Learned the hard way decades ago during the carburetor era that not all fuels are delivered equal. Gasoline may start out as gasoline, but a lot can happen in transport, storage and time. When I was a poor college student, I was buying whatever was the cheapest and constantly having problems, rebuilding carbs, replacing carbs, filters, etc. I installed a glass sediment bowl fuel filter and emptied the crud out of it monthly. Then as they do when you get into college, I started getting all these offers in the mail to apply for credit cards. One was from Exxon. So I got an Exxon card and started buying gas exclusively from Exxon. After a while, I realized that I wasn't having any more problems with my car and there was nothing in the sediment bowl to empty. Modern cars aren't as obviously impacted by dirty fuel because modern fuel injection runs 30-40psi through injectors rather than at 2 - 5 psi through a carburetor but you still would like to be sure you're getting clean fuel.
Many years later I bought a used boat that had been sitting for a couple of years and took it to an outboard engine specialist for recommissioning. He got it running good and gave me the advice to never buy no-name brand fuel at the marinas, but rather only use either Exxon or Chevron. He was convinced that their additives helped keep the gas from going stale so quickly which is important in a boat that isn't in constant use.
Recently tho, I'm getting suspicious of a local Exxon station. I sometimes think I've gotten a tankful of 87 after paying for 93 because a couple of times in the last year it would ping till I refueled or added some octane booster. I read somewhere that the pumps with three separate hoses were better because there was no chance of blending octanes. I haven't seen a pump like that in a long time. I don't know how much 87 is already in the hoses when you select 93. If it were critical for filling your lawnmower, it'd be a concern, but in a 17 gallon fillup, surely its only a quart or two.
omgimali (11-08-2016)
For my runaround car with it's little 1200cc engine I use whatever is convenient, normally Shell Fuelsave unleaded which is about 95 Octane.
However for my Triumph with it's twin carburettor 6 cylinder engine I use Shell V-Power Nitro+ which is 99 Octane rated. This car would have been run on 4 Star Leaded petrol but was designed to run on 5 Star back in the 60's and it loves the V-Power!
My XJ will also get the V-Power fuel once I've finished my renovation and it's back on the road. The first time I used 99 Octane in my old XJ was like giving it amphetamines.
To start my car runs on (EU) RON95 E10. When warm it runs on RON115 LPG.
My car was made as RON91 was still available. So the lowest grade will do. And as it can take E10, it'll get E10. I've never put anything else in it since buying it last year... No performance problems. The old 3.2l will do it's top speed and more (according to GPS).
Daim (11-08-2016)
Haha dang wawa that grocery store has gas stations? , so now all bigger stations are taking over like wawa because of the tax increases, and we never have self serve in sc..
UK and German octane ratings are different than here in the US. Second, most US states don't sell gas without 10% ethanol (if you can find ethanol free gas, buy it, it is much better). I use Sunoco 93 octane (US method). WaWa here in VA is 92 octane whereas most others are 93. For what it is worth.
NJ had low gas tax and no "self serve" ... anybody going through always filled up. The tax went up .23 on 11/1 .. so it's going to make NJ gas less appealing. My local Shell station had to switch to Conoco -- Shell gas was alway a few cents more and with WAWA around he was loosing to much business
