I'm about to install my T605 kit using the wonderful X308Bluetooth.pdf guide.
Opening up my centre console I've discovered it has a connector already attached to the 10 pin AMP multilock connector. The pins seems to be for microphone, ground and battery...but this car doesn't have a car kit in the boot and it doesn't have a jaguar microphone anywhere. I can't quite see where this cable goes but it appears to be bundled with the cables heading towards the back of the car.
I assumed if it was for a microphone it would be heading towards the front of the car and there'd be a factory microphone installed somewhere.
Any ideas?
Here's a picture:
(The connector in question)
Strange it had a plug going into the phone connector already... maybe a PO did something strange? The phone module, if installed, should be under the center console container where the plug is. I think some EU markets had a trunk-mounted phone unit, but then you'd think all the wiring would be connected to it.
