What's the easiest way to replace engine mounts?
Lift the engine slightly or lower the subframe slightly.
I lift the engine but that is my preference. Tilt it over to the side to gain more access and do them one at a time.
Warranty time is 2.3 hours so 2.3 x 1.5 = 3.45. (real world time is warranty time, times time and a half (Warranty X 1.5)).
I would charge 3.5 hours labor.
bob
bob
vdpnyc (04-29-2017)
Sorry to 'jump in' on this thread Bob, but I am removing my engine/gearbox complete, as you know that's no mean job. I've got virtually everything off including down-pipes/CATS but how to get at the engine mount nuts is baffling me, I don't seem to have any tools to get in to the tight space? Tried crows foot spanners, all sorts?
The following 2 users liked this post by motorcarman:
Daim (05-02-2017),
euphonium01 (05-03-2017)
Received 2,192 Likes
I jack up the engine with both mounts unbolts from the frame as high as the engine will go. you do need to unbolt the rack from the frame to remove driver side mount(don't unbolt from the column) and some models the studs are obnoxiously too long so you either unbolt the frame (don't remove the bolts) just lowered from the body. or thread a nut over the studs, cut them down a 1/4" and chamfer and run the nuts back off to clean the threads and viola' they slide right in
The following 2 users liked this post by Brutal:
Coventrywood (06-10-2017),
motorcarman (06-10-2017)
Thanks - I've already had them changed and mentioned the aforementioned comments to the mechanic - the mechanic ended up removing the rack and pinion to access them from below - no idea of this was the ideal method, but it left me with a misaligned steering wheel (which they said they will try to correct, but requires yet another service appointment...)
I've already thanked those advising me to remove the Torx bolts from under the car, and it worked a treat (I was removing the engine anyway for a number of reasons). Once removed, the engine and box flew out, now after some detailing and a different gearbox, it's all ready to drop back in... anything I should know before I fit it back in this weekend?
