What's the Easiest way to set crankshaft on tdc ?
Hi guys I want to change primary tensioners and chain guides . Now I know I should lock cams on both banks with the cam locking tool which is not expensive tool . Now what about the crankshaft?
Can I just put mark on the crankshaft and check piston number 1 if its on the highest point ?
What's the easiest way to set the crankshaft timing ?
thank u .
thank u .
This is not easy to fit plug in the CPS location i don't even know where is that sensor that looks complicated. Now since my timing is okay can I just use marks by pen or its risky?
There's at least a couple PDF's on timing chain replacement, and many threads on it. Timing tool kits are pretty cheap on ebay too (70 bucks or so last time I looked)
Here's the link for the PDF procedure from the forum's large files section that goes over the process in detail http://www.mediafire.com/file/wnuacw...ement.pdf/file
RA110623 (05-21-2020)
cyber3d
04-22-2016 01:52 AM
jindracusin
03-22-2016 05:33 AM
mattysta
08-28-2010 08:54 PM
