Wheel Bearing/ABS Ring Trick
I'd read several posts here stating that changing the wheel bearings is very difficult and almost impossible without some $130 special tool (Laser 5537) for removing the "ABS ring" on the back of the wheel hub. I've just finished doing the job without the tool and wanted to post how. It's actually quite simple. Once the wheel is off, simply remove the ABS sensor itself from it's boss (using an 8mm wrench I think it was). Then, wedge a screwdriver or some other tool (I ended up using large torx bit) between the ABS sensor boss and the "teeth" of the ABS ring. Now, turn the wheel with a pry bar. This works like a charm and negates the need for the expensive tool or a 2" 12-point socket (which others have said works but is also pretty rare.) I admit, my ring may have been looser than what some people on here have encountered but maybe not.
I'm pretty sure you can reverse the procedure for putting it back on (though I'm not sure how one would torque it to spec this was) but I'll find that out tomorrow when I put it all back together.
The following 3 users liked this post by Rob_hook:
Neat trick.
You better come back with the results because I'm subscribed now![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
To torque back to spec, you need to wedge again, get a grip on the center of
the hub with a torque wrench. That could be a nut welded to a bar that fits
between two of the studs.
How are you dealing with the actual removal and installation of the
bearing itself?
cheaper source for the special tool:
https://www.jaguarforums.com/forum/x...ght=laser+5537
bearing itself?
I have a shop press and am using that for the bearing. I put it back together this morning and haven't torqued the ABS ring yet. I'll probably use the nut welded to a steel bar idea though.
As for the bearing, be careful when pressing the hub back into it. These bearings aren't stable as far as the inner race goes. Make sure you're pressing on the hub and supporting the bearing from the back BY THE INNER RACE, not the outer race and not by the carrier.
Terryble (01-08-2021)
Socket from Sears worked like a charm for me... still have it (should). The nut was a bit rusty, so I used plenty of WD40 or something like that day before.
Be careful wedging things between nut, the nut is some kind of cast iron - may crack like glass.
The driver's side ABS ring was on so tight I had to chisel and grind it off! What a pain. This was after soaking it with penetrating oil, heating it with a torch, using two breaker bars (which both broke), etc etc. Even after I'd cut through most of it and then chiseled it until it cracked all the way through, it still wouldn't come off with a breaker bar! I had to use the chisel and a sledgehammer to finally get it to turn!
Bottom line: if you're going to do this job, be ready for it to be a REAL PAIN. Not every time...but it's possible at any time. Also, I suggest you have a good 3/4 inch drive breaker bar. A Craftsman one is only $27 on Amazon.
XJRay (01-21-2017)
XJRay (01-21-2017)
Received 6,321 Likes
Pleased to confirm I completed the job. Challenging enough, but ABS ring came off after using WD40 and the impact wrench of course. 22 ton press was struggling with the bearing but I got there in the end. Having the right tools is important, I rented a ramp and the heavy tools in a local DIY workshop.
Noud
Noud
The following 2 users liked this post by Noud:
motorcarman (01-22-2017),
xjay8 (03-24-2017)
It's funny, just wanted to add this here:
There's a video on youtube, I won't link it directly but any jag wheel bearing search will find it. Some guy, using a 2" socket and ranting about "why they make you spend money when you can do this!" and proceeds to show him using an impact with that socket - While the socket dances, and slips, and strips all over the ABS ring in both directions lol. Yep, seems SOOOO much less invasive that way!
(not to say that with it pressed on the floor, that it wouldn't have a better grip, but seriously, if you're gonna make a video about an alternative, don't show the alternative looking so flaky!)
I bought a 2" 12-point socket and used my heavy duty impact gun. After a few times with that the abs ring came of without a mark on it. It was rusty. I paid to have the bearing pressed out and new one pressed in by a machine shop since they have the proper tools. The biggest amount of time I spent was customizing the ball joint separator I bought. Otherwise the job was pretty easy and all in for less than $160 parts and tools. Jaguar wanted almost $700
xjay8 (03-24-2017)
clubairth1
29
05-10-2024 12:57 PM
