Wheel Question!
If your car is X308, you could use BMW wheels but with quite a bit of modifications:
1. The centre bore has to be machined to 73.8 mm (not 74.1 as you mentioned)
2. The Jag PCD is 5 x 120.65 so you will also have to have the bolt holes and their tapers machined to this PCD (from BMW's 5 x 120.00).
See the attached write-up by somebody who has adapted BMW wheels.
The factory offset is 33 mm so the BMW wheels you mentioned (30 mm front) will be fine but will be sitting 10 mm out compared to stock 8 in. wide rims. As for the rears, 35 mm is also ok but at 9.5 in. the tyres will be sitting 3/4 in. out compared to stock so check for clearance to the wheel arches.
Vegas_Jag (04-26-2020)
